Old Mon, Mar-19-2018, 02:21:11 AM   #11
Paulo M
Default Re: 2004 AW/Cinn 6MT - Rod bearing issue - Rebuild, sell as-is, part out, or?
How much is the rebuild? If it’s under $5k, If it was me, I’d rebuild it. If that car has clean title then it’s a very nice example with that color combo and 6spd. Exterior does look to be in rough shape, but that’s an easy but costly fix.
BREMBO BBS DIXIS
Old Mon, Mar-19-2018, 02:36:12 AM   #12
bmwahba39
bmwahba39's Avatar
Reputation: 0 bmwahba39 is on a distinguished road
Originally Posted by Paulo M View Post
How much is the rebuild? If itís under $5k, If it was me, Iíd rebuild it. If that car has clean title then itís a very nice example with that color combo and 6spd. Exterior does look to be in rough shape, but thatís an easy but costly fix.
The exterior looks decent to me? For the miles.
Echoing what others are saying. This car doesn't need to be parted out.
Jump to top bmwahba39 is offline   Reply With Quote
Old Mon, Mar-19-2018, 02:45:50 AM   #13
Paulo M
For the miles sure, but op himself said it’s not in the best of shape exterior wise. A white car in decent exterior condition will look mint in pictures. But it could just be me, maybe all it needs is pdr and paint correction. Interior looks mint regardless of miles.
BREMBO BBS DIXIS
Old Mon, Mar-19-2018, 02:51:25 AM   #14
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
If you want to keep the car, buy a used engine and have it replaced, then part out the blown engine.
If you want to get the most money out of it and move on, part out the car.
If you cant or don't want to fix it but also don't want to kill the car then sell it to the mechanic so it can be reborn.
Current BMW stable: '00 R1100S, '09 HP2S, '12 R1200GSA, '07 335i, '03 M3, '00 Supercharged 323iT
Jump to top GeorgeH is offline   Reply With Quote
Old Mon, Mar-19-2018, 03:28:48 AM   #15
m3vancity
Reputation: 0 m3vancity is on a distinguished road
It just boggles my mind that at 160k the bearings havent been replaced. With that im assuming the vanos hasnt been addressed as well. Id go with a used motor personally. Rip s54
Jump to top m3vancity is offline   Reply With Quote
Old Mon, Mar-19-2018, 05:26:09 AM   #16
ftc3
Reputation: 0 ftc3 is on a distinguished road
I would go this route too
Originally Posted by GG///M3 View Post
Buy a used motor. Replace rod bearing, and enjoy
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is offline   Reply With Quote
Old Mon, Mar-19-2018, 05:51:56 AM   #17
Another vote for swap used motor, or rebuild.
All DIY: 330 ZHP steering rack, diffsonline 4.1 diff with rem polish, E60 short shifter lever, AKG black diff bushings/subframe bushings, Rogue rtab, Rogue RSM with reinforcement, WPC rod bearings, Beyer driveshaft, full SS (SS stepped V1, catted S1, resonated S2, SS sport), Sachs clutch/flywheel, rear main, VANOS bullet proofing with anti-rattle, valve adjustment, cooling refresh.
Old Tue, Mar-20-2018, 04:33:17 PM   #18
e46erick
Reputation: 0 e46erick is on a distinguished road
Keep it. If you were in Socal I would buy it right now
Jump to top e46erick is offline   Reply With Quote
Old Tue, Mar-20-2018, 06:14:26 PM   #19
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Used motor gets my vote.
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Sun, Apr-08-2018, 04:15:44 AM   #20
jbarajas19
Reputation: 0 jbarajas19 is on a distinguished road
I'll gladly take the whole interior away from you! PM me!
Jump to top jbarajas19 is offline   Reply With Quote
Discussing 2004 AW/Cinn 6MT - Rod bearing issue - Rebuild, sell as-is, part out, or? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
