Old Wed, Oct-25-2017, 10:09:14 PM   #1
Default Understanding RealOEM (ETK) hardware (nuts/bolts) specifications
Hi there,
Sometimes you need to replace a nut and you don't want to go to a dealer or order online, just down the street to the hardware store for a $0.40 nyloc nut.
Easy part is everything (bmw) is metric.
M14x1,5 (commas in Europe are like periods here) is a nut or bolt that has a diameter of 14mm and the pitch is 1.5mm. Easy enough.
What I'm hoping is that someone knows what these other specs BMW gives on their hardware as I'm trying to figure out if I need coarse, fine or extra fine on certain hardware.
Example: (from realoem)
02 Self-locking collar nut M8-8 ZNS3 6 31316769731 $0.38
03 Plate 2 31332229427 $3.97
04 SELF-LOCKING HEX NUT M14X1,5-05 ZNS3 31106774714 $1.12
05 self-locking flange nut M10x1-8 ZNS3
So in this case, what does the 8 mean after M8? I'm thinking ZNS3 is some sort of zinc coating/hardening rating.
the M14x1,5 is easy like I put above, but what does the -05 mean?
Here's another, M10x1-8 - is this a M10 nut (10mm) with a 1mm pitch? What's the 8 doing after the 1?
These examples above are all nuts, so no length to worry about like a bolt, e.g., m10x1,5x30mm
Are these extra numbers hardness ratings? If so, how do we know if a pitch is coarse or fine?
Some size of nuts/bolts only have one type of pitch, but some like 8 and 10mm have coarse and fine and that's the part I'm needing to know.
I've search but can only find info about the diameter and pitch which I already know when it's laid out in a normal way like M14x1,5.
Appreciate any knowledge here and maybe this can help others in the future.
I've attached a nice chart of common sizes as an helpful guide.
Thanks
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · WPC'd OE bearings · oil catch can · fan/SAP/washer delete · CSL battery
GroundControl S/A Koni (Hyperco/Eibach 300/550) + tall RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · SPC alum rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · 12mm/10mm F/R spacers · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Wed, Oct-25-2017, 11:04:46 PM   #2
bimmerfan08
bimmerfan08's Avatar
Default Re: Understanding RealOEM (ETK) hardware (nuts/bolts) specifications
The grade of the metal is usually stamped on the bolt/nut. Example: 8.2 which is low carbon steel.
Old Thu, Oct-26-2017, 03:36:45 AM   #3
Anybody?
My best guess so far is the -8 or -05 at the end probably is the grade, but then that means that some of the specs of the nuts and bolts are missing the pitch like M8-8 - are we to believe it's a grade 8 m8 nut? But what pitch?
But then on the shock nut, M10x1-8, it makes sense - an m10 nut with 1mm pitch & grade 8 steel, if that's what they actually mean. It's not consistent
Anybody work in the parts department at a BMW dealer?
_
Old Thu, Oct-26-2017, 06:38:45 AM   #4
I M Legend
maybe try contacting Mr. Metric from the video?
Old Thu, Oct-26-2017, 07:00:35 AM   #5
Is he a BMW guy?
It just seems to be BMW issue, that they provide the full specs on some hardware and not other. Or maybe there's a trade secret, like if it's not listed is coarse and if it's listed, it'll be fin, for example. IDK, that's why I'm hoping there's a BMW employee or someone who knows the deal lol.
_
Old Thu, Oct-26-2017, 08:39:46 AM   #6
http://images.gasgoo.com/attachment/.../001402193.pdf
ZNS3 is a Zinc Flake Coating as outlined in the PDF.
If the pitch isn’t listed you will need to use first hand experience, cross reference with a possible bolt also used in the application, reference internet images or guess. ETK is full of missing information, but is otherwise an invaluable reference tool.
Old Thu, Oct-26-2017, 01:42:55 PM   #7
SliM3
SliM3's Avatar
Pretty sure -8 indicates strength grade, but if that's the case, it's standard class nomenclature and not metric.
Tensile = 150,000 psi
Yeild = 130,000 psi
Same as above
Same as above but a grade 5
Tensile = 120,000 psi
Yeild = 92,000 psi
Real OEM, and most BMW catalogs, are hard to decipher. Usually they're populated from a master parts catalog and whomever translates for different countries doesn't necessary apply the correct nomenclature.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Thu, Oct-26-2017, 04:07:50 PM   #8
nrubenstein
Yeild = 130,000 psi
Same as above
Yeild = 92,000 psi
I'm pretty sure that M14x1,5 should be translated as M14x1.5, not grade 5 M14x1. Otherwise, I agree.
Old Thu, Oct-26-2017, 05:08:27 PM   #9
nowanker
"He's no wanker!"
Got no idea what the second number means.
But I'll bet my left nut (pun intended) that it isn't a reflection of the strength category.
The very thought of using an imperial rating on a metric fastener would be appalling to ANY German. Probably the very thought that imperial fasteners exist appalls them!
Old Thu, Oct-26-2017, 05:13:05 PM   #10
That's actually a great point!
Thanks Braymond, that's the closest I'll get to answer I think - we'll just never know the pitch on some of these just looking at realOEM as that info is just missing.
Yes, M14x1,5 is def 1.5mm pitch as I said earlier, the "," is a "." In europe.
_
Discussing Understanding RealOEM (ETK) hardware (nuts/bolts) specifications in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
