Old Sun, Sep-17-2017, 09:46:45 PM   #1
Gibbo205
Reputation: 0 Gibbo205 is on a distinguished road
United Kingdom
Default Ran a 13s flat quarter mile, reckon I can get twelves?
Hi there
For fun I took my track car to the 1/4 mile Santa Pod (a touch uphill) for a quarter mile run:
Car was in track geo and regular road pressures of 33psi front and 35psi rear.
First run: 2.355s 60FT, 6.02s 330FT, 8.93s@85.87mph 1/8, 13.4793@109.11mph
On the first run I just ran gear box in S3 all the way, bit slow on gear changes.
Second run: 2.165s 60FT, 5.70s 330FT, 8.56s@87.38mph 1/8, 13.0439@110.18mph
Once into second gear I moved SMG from S3 upto S6, faster gear changes and getting on power quicker helped.
Then it rained, was gonna try an S6 run all the way and get into WOT quicker, think it would of got a high 12 then?
Here is a video of my 13s run.
Jump to top Gibbo205 is offline   Reply With Quote
Old Sun, Sep-17-2017, 10:28:26 PM   #2
stash1
Default Re: Ran a 13s flat quarter mile, reckon I can get twelves?
Nice, pretty quick time-congrats! What's your mod list? Any weight reduction?
'04 AW/IR...some mods
Old Sun, Sep-17-2017, 10:40:24 PM   #3
2006E46M3fan
2006E46M3fan's Avatar
Congrats as well and same questions!
Jump to top 2006E46M3fan is offline   Reply With Quote
Old Sun, Sep-17-2017, 10:49:59 PM   #4
Gibbo205
United Kingdom
A lot of weight reduction its a track car built to CS spec, so still my driver on the road too, rear cage, buckets, harnesses etc.
All infotainment, AC, air bags, seatbelts removed etc. It weighs around 1300kg with fuel, but should be down to 1250kg next month.
Still road legal, still has full interior in front, carpeted in rear.
Power wise nothing major just NA bolt-ons, CSL air box, CSL ECU, map sensor, TTFS tune, euro headers, de-cats, stock exhaust.
Old Sun, Sep-17-2017, 10:52:56 PM   #5
Gibbo205
United Kingdom
Second run I walked off the line in S3, then booted it, once into 2nd gear I went into S6 which gave me 13s flat.
First run I did whole run in S3, gear changes too slow.
Shame it rained as 3rd run I was going to try a run in S6 all the way and 4th run maybe give the LC a go. Then I would have fiddled with tyre pressures as I was just running what it said on door jam.
Tyres are MPSS 255/40/18 square setup by the way.
Old Sun, Sep-17-2017, 11:37:50 PM   #6
HassanEido
HassanEido's Avatar
Lebanon
You need cams and and pipes you'll be in 12s for sure. Fwiw, that intake sounds amazing, which cf box is it? Karbo? Gsr?
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Mon, Sep-18-2017, 12:04:04 AM   #7
icecream
Registered Apples
icecream's Avatar
Did you use launch control and did you use it corectly? I think it's go to the floor slow to raise rpms to 4k (with csl tune) before dumping the clutch.
Old Mon, Sep-18-2017, 12:32:54 AM   #8
EricSMG
40 something
The SMG royally sucks off the line in any non-launch control situation. If you're just hitting the gas from a stop you're giving up tons of 60ft time.
I would think with a proper launch you'd be in the 12s easily as-is.
2004 E46 M3 6MT SG/Black
Old Mon, Sep-18-2017, 12:54:58 AM   #9
Malloy
Reputation: 0 Malloy is on a distinguished road
Nice trap speed, that car is moving!
Jump to top Malloy is offline   Reply With Quote
Old Mon, Sep-18-2017, 03:09:28 AM   #10
stash1
Oh, for sure! If he could improve his 60' time by even 1/2 a tenth...that would put him in the 12's!
Discussing Ran a 13s flat quarter mile, reckon I can get twelves? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
