Old Sun, Mar-26-2017, 07:56:59 PM   #1
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Reputation: 0 yosshaa is on a distinguished road
Default Koni strut install gone terribly wrong.
Second weekend trying to set these front struts in their collar.
Pins are line up. Call and strut are greased with my burrs or anything to inhibit them from sliding into place.
Collars are. It damaged in any way, pinch bolts are all the way out
Yet.
Drivers side seats like this... 2" under collar with alignment pin sitting in collar
And passenger side won't go past this... .75" under collar with pin sitting above collar
So wtf! I've even jack the lower control arm up with no pinch bolt and that's as far as it goes.
I'm at a loss unless it's suppose to be offset for some reason.
2006///M3-ZCP-SMG-IB/Dove
43,779 E46 M3's produced for NA
26,202 E46 M3 Coupes
2,410 E46 M3 Coupes with ZCP Package
843 US / 54 CA ZCP in Interlagos Blue
366 US / 21 CA ZCP in Interlagos + SMG
154 US / 6 CA ZCP in Interlagos with N5TT (Dove Gray)
76 US / 2 CA ZCP in Interlagos + N5TT (Dove Gray) + SMG
WTB 1 Rear mint ZCP wheel no tire or center cap needed P/N 36112282999
Jump to top yosshaa is offline   Reply With Quote
Old Sun, Mar-26-2017, 08:23:40 PM   #2
M3 DJ
Reputation: 0 M3 DJ is on a distinguished road
Default Re: Koni strut install gone terribly wrong.
Mine look like your drivers side. If they aren't sliding in I would try and use a scotch pad inside the knuckle to take away any corrosion thats keeping it from sliding in. You can also use a pry bar to spread open the knuckle a bit from the slit where the bolt compresses the strut.
Jump to top M3 DJ is offline   Reply With Quote
Old Sun, Mar-26-2017, 08:25:59 PM   #3
nickpiper12
nickpiper12's Avatar
Reputation: 0 nickpiper12 is on a distinguished road
Try opening up the collar on the passenger side, take a pry bar or alike to expand it. You should be able to slide the strut further into the knuckle for proper seating
2003.5 E46 M3 SMG | Alpine White/Black
2000 E46 "M3T" 6MT | Steel Grey/Tanin Red
2011 E91 Touring Sport 6AT | Alpine White/Chestnut Brown
Jump to top nickpiper12 is offline   Reply With Quote
Old Sun, Mar-26-2017, 09:01:00 PM   #4
I use a big flat head screw driver to leverage the pinch collar up, like Nick says with the pry bar, as it's easy to handle.
Your first picture looks intalled correctly fyi.
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Mon, Mar-27-2017, 12:14:59 AM   #5
yosshaa
Proud ZCP Owner
yosshaa's Avatar
Used a pry bar to open it up. Checked part number, took everything back a part. Checked for points of hang up.
Just don't get it. Gonna drive around a bit and check ride heights to see if that is off.
Old Mon, Mar-27-2017, 01:19:25 AM   #6
I wouldn't drive the car with the one strut more than an inch away from being seated properly.
Old Mon, Mar-27-2017, 02:36:44 AM   #7
EricSMG
40 something
Agreed - it's not right, don't drive it. I bet the car is sitting croaked anyway.
Take it part - lightly sand the inner clam shell and the outside of the Koni, feeling for what's limiting movement and resolve the issue - then it should slide down and bottom out, by hand. Also check the channel that the alignment pin slides down into - it could be getting hung up half way down.
Current - 2017 F82 M4 ZCP DCT Blk/Blk Fully Loaded
Current - 2004 E46 M3 6MT SG/Black
Sold - 2018 F80 M3 ZCP 6MT AW/Black Cloth "stripper"
Old Mon, Mar-27-2017, 04:00:53 AM   #8
Maybe you're being forced, by limited space, to try to slide the strut down at an angle and that's causing the hang up?
Old Mon, Mar-27-2017, 06:18:12 AM   #9
The One
Reputation: 0 The One is on a distinguished road
If you are having trouble opening up the collar, then try using a hex key:
Find the largest sized hex key where the flats will fit into the collar. Then turn the hex key so that the corners of the hex can hold the collar open.
Or get one of these:
https://www.ecstuning.com/b-schwaben...-tool/scw3435/
Hope this helps.
Jump to top The One is offline   Reply With Quote
Old Mon, Mar-27-2017, 01:20:46 PM   #10
vp special k
Reputation: 0 vp special k is on a distinguished road
Viet Nam
This...knowing that its not seated correctly and still going for a drive isn't the wisest thing to do.
Jump to top vp special k is offline   Reply With Quote
Discussing Koni strut install gone terribly wrong. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
