Old Tue, Feb-28-2017, 04:13:42 PM   #1
aznniche
aznniche's Avatar
Default 6th gear whine
Issue solved! It was very low on transmission fluid. Only 1/2 liters came out. Put in close to 2 liters and no more whistle noise.
Under load, I hear a whine only on 6th gear. The noise does not happen when I'm not on the gas or lower gears. Would this be related to transmission or differential?
I have a SMG if that matters. Differential fluid changed out 500 miles ago with oem stuff.
Old Tue, Feb-28-2017, 04:17:38 PM   #2
titus59
titus59's Avatar
Reputation: 0 titus59 is on a distinguished road
Default Re: 6th gear whine
I believe smg and manual are same transmission. As for the whine, I'd vote transmission.
Sent from my SM-G930V using Tapatalk
Jump to top titus59 is offline   Reply With Quote
Old Tue, Feb-28-2017, 06:19:02 PM   #3
mleveroni
Reputation: 0 mleveroni is on a distinguished road
Do you have aftermarket bushings for the subframe, diff, or trans?
2002 M3 Carbon Black 6MT
ARP Headstuds|ARP Rod Bolts|Beisan Vanos|Topspeed Exhaust|AR20's|Ebay Headers|Turner Subframe Plates|ZCP Rims|Custom Rear Strut Bar|AKG Bushings|ST XTA Coilovers|Clutchmasters FX300 Clutch/Aluminum Flywheel|RK Tune
Jump to top mleveroni is offline   Reply With Quote
Old Tue, Feb-28-2017, 06:23:39 PM   #4
titus59
titus59's Avatar
Nope, all original with 79,000
Old Tue, Feb-28-2017, 07:48:10 PM   #5
Joshe46
Joshe46's Avatar
Mine wines a little bit when not under load also. But I have poly diff bushings( A mistake).
Jump to top Joshe46 is offline   Reply With Quote
Old Tue, Feb-28-2017, 11:58:54 PM   #6
aznniche
aznniche's Avatar
All oem rubber.. Wonder if this a sign of low transmission fluid.
Old Thu, Mar-02-2017, 11:55:33 AM   #7
aznniche
aznniche's Avatar
Added a video of the noise. Does this sound the same as you guys have? More of a whistle than a whine? Gets louder when I'm speeding up in sixth.
Old Thu, Mar-02-2017, 12:04:32 PM   #8
Joshe46
Joshe46's Avatar
That sounds different than mine. As you said that sounds more like a whistle than a whine. My noise only occurs( or I can only hear it when I let off throttle and theres no engine noise because no load. Check your diff fluid level sooner rather than later and might as well change it while doing that. Start there.
Old Thu, Mar-02-2017, 12:09:10 PM   #9
BTB
BTB's Avatar
If it only happens in one gear, I'd have to think its transmission not diff related. Does seem odd though... When was your trans fluid last replaced and/or how many miles on it?
edit: I see from the video over 200k miles on car. Transmission fluid change can't hurt if its been a while
My Journal
Old Thu, Mar-02-2017, 05:10:42 PM   #10
aznniche
aznniche's Avatar
Diff fluid was change out < 500 miles ago. It was low and dark, but that didn't resolve the noise. Tranny fluid has been about 3 years. I plan to change it out to see if this resolves the issue. No good way to determine if you're low on fluid besides loosening the fill bolt and seeing if it comes out..
Discussing 6th gear whine in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
