Old Sat, Jul-14-2012, 03:31:01 AM   #1
e36m3rt
Reputation: 0 e36m3rt is on a distinguished road
Default 99 m3 wont go into gears at a stop cant find any solution :(
hi guys I have had this problem since i changed the clutch ; when i start the car and keep my foot on the clutch pedal is easily shifts but second press it wont it just doesnt go into any gears except 5th so i have to force it all the times..if the car is moving no problems at all...
1999 e36 m3 82k miles
i ve replaced;
all the bushings
f1 racing ltw flywheel , stage 2 clutch kit
ssk
slave cylinder
fluid with rl and rp
master cylinder
its just getting worse and nothing has fixed...
if anyone can give me an idea which will fix the problem ill not only appreciate and also reward him im that desperate right now
any ideas?
Jump to top e36m3rt is offline   Reply With Quote
Old Sat, Jul-14-2012, 03:42:17 AM   #2
englishtom1596q
englishtom1596q's Avatar
Default Re: 99 m3 wont go into gears at a stop cant find any solution :((((
synchros?
Old Sat, Jul-14-2012, 04:08:12 AM   #3
V8HAHA
V8HAHA's Avatar
Reputation: 0 V8HAHA is on a distinguished road
Transmissions are cheap for the E36, usually 250-300. I would just replace the tranny and enjoy the M.
Jump to top V8HAHA is offline   Reply With Quote
Old Sat, Jul-14-2012, 04:09:10 AM   #4
enderw88
Rolling Restorer
enderw88's Avatar
Reputation: 0 enderw88 is on a distinguished road
Does it make noise trying to get into gear, or just take a lot of force? But internal trans problems seem like it...
Craig, Tucson AZ
New Buyers Please Read
Originally Posted by JitteryJoe View Post
Buying the car is going to turn out the be the least expensive part of this experience. Fun though.
Jump to top enderw88 is offline   Reply With Quote
Old Sat, Jul-14-2012, 05:14:31 AM   #5
englishtom1596q
if you pump the clutch does it make a difference? as said above it sounds internals (synchros) just buy a good used trans
Old Sat, Jul-14-2012, 09:57:58 AM   #6
falciott
falciott's Avatar
Reputation: 0 falciott is on a distinguished road
If I were you, before I start looking for used trans, I'd change the transmission fluid. I use Royal Purple, and I find shifts to be smoother then original BMW fluid.
1997 Glaciersilber M3.
Clear lights, Corsa RSC36, DJ Auto with TFX retrofit, Blind spot monitoring system, Illuminated ZHP knob,Brushed aluminum look console and bits,Flat bottom MTechnic steering wheel, Becker Grand Prix with bluetooth, Motion sensor HD dash cam, BMW Homelink, Keyless entry, RE short shifter,CSL reps, Mason strutbar,Reverse sensors, Automatic rain sensing wipers, everything else? Stock!
Jump to top falciott is offline   Reply With Quote
Old Sat, Jul-14-2012, 11:18:35 AM   #7
prostreeter
Reputation: 0 prostreeter is on a distinguished road
Are you sure there is no air in the system?
Jump to top prostreeter is offline   Reply With Quote
Old Sat, Jul-14-2012, 11:37:08 AM   #8
cmcon98
cmcon98's Avatar
Reputation: 0 cmcon98 is on a distinguished road
The clutch is dragging (not disengaging fully). Either there's air in the hydraulic system, a component is bad (such as the master or slave cylinder) or there's a mechanical problem with the clutch, such as a broken pivot pin or warped disc.
I highly doubt it's a problem with the transmission, as what you describe sounds more like a clutch failure mode than a tranny failure mode.
'99 M3 'vert, 5-speed, cosmos/sandbeige, bone stock except Konis and speakers.
Jump to top cmcon98 is offline   Reply With Quote
Old Sat, Jul-14-2012, 08:25:37 PM   #9
V8HAHA
V8HAHA's Avatar
It seems he had the issue before he replaced the clutch so it sounds like a synchro issue to me.
Old Sun, Jul-15-2012, 04:47:26 AM   #10
e36m3rt
thanx guys for the replies ,
since car only has 80k i think tranny should be fine imo..
i ve changed the fluid 3 times within 6 months, i ve tried two different red lines and now royal purple no difference at all
pumping the clutch again doesnt solve it feels like im not even pushing the clutch at all and i dont think syncros because when the car is moving it shifts awesome no problems at all it just happends at a stop
ive changed master and slave, no noise at all while shifting
i dont think there would be air cause mechanic bled it 4 times within 6 months and none of those tries made a difference and if there was a air would it make this problem everytime? :S mechanic said he would have realized when he was replacing the clutch if the pivot was bad .. i ve no idea what to do
Discussing 99 m3 wont go into gears at a stop cant find any solution :( in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
