Old Fri, Oct-20-2017, 10:07:28 PM   #31
binary
Reputation: 0 binary is on a distinguished road
Default Re: Installed Spacers, now ticking noise
Originally Posted by arkow View Post
got you, will look into getting shorter bolts. I got a torque wrench and i do 88lbs tq on the bolts..
I think I am having the same ticking noise. Only occurs when the car is warmed up, passenger front corner.. AND the wheel is being turned to the left.
I have 10f/12r macht snell spacers and ZCP wheels with locking nuts.
I wanted to buy studs instead of bolts anyway. I know the Apex studs are annually consumable. Is this true for all wheel studs? If not, is there a different company's studs (hehe) I can buy that aren't consumable? Or at least not annually consumable, seems silly for a street car..
Jump to top binary is offline   Reply With Quote
Old Mon, Oct-23-2017, 03:25:36 PM   #32
nrubenstein
Reputation: 0 nrubenstein will become famous soon enough
It should not matter up front, unless you are stupidly over length.
Edit: All studs should be regarded as consumable. That said, they are probably being conservative, and also assuming a *lot* of wheel changes.
[B]2011 BMW M3 (E90) Alpinweiß/Cloth - Slicktop stripper, TCK D/A Konis, AS SSK
2006 GMC Sierra 2500HD 4WD - Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - Konis, AS SSK, JBL MS-62C, IDQ-12v3, JBL MS-8
1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod
1995 M3 Dakargelb/Black - S50B32/S6S420G, Diffsonline 3.91, H&R/Bilstein, Hotchkis, AS SSK, etc...
1990 325is Brilliantrot/Tan - GC/Bilstein, Sway
1989 325is Alpinweiß/Black - Decontenting...
1989 M3 Alpinweiß/Black - S62B50 in progress...
Hers: 1996 Porsche 911 Turbo Black/Black - UMW LTW Flywheel, Bilstein
Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, 272 cam, H&R/Bilstein
Jump to top nrubenstein is offline   Reply With Quote
Old Mon, Oct-23-2017, 05:21:25 PM   #33
arkow
Reputation: 0 arkow is on a distinguished road
I installed the spacers with stock wheels and ticking noise is gone so the extended bolts must be too long. If anyone is buying spacers with extended bolts be aware that they might not fit if you have aftermarket wheels..
Jump to top arkow is offline   Reply With Quote
Old Mon, Oct-23-2017, 08:03:58 PM   #34
arkow
So i been reading about the correct wheel bolt torque; the F80 M3 which i got the wheels from calls it for 104ft-lb, but the E46 M3 is 88ft-lbs, I should be using the E46 M3 torque specs, correct?
Old Mon, Oct-23-2017, 11:19:08 PM   #35
rovert604
rovert604's Avatar
I’ve used 88lbs for the 12 years I’ve owned E46s without issue.
--Trevor in 604--
Vancouver, BC, Canada
Jump to top rovert604 is offline   Reply With Quote
Old Mon, Oct-23-2017, 11:50:42 PM   #36
binary
Thank you. I had no idea (about both).
Old Mon, Oct-23-2017, 11:56:29 PM   #37
arkow
Cool, so i am good as i been using 88lbs as well.
Thanks
Old Tue, Oct-24-2017, 05:41:35 PM   #38
arkow
*** Ticking noise is fixed, i had to grind down the extended bolts (43MM) on the driver side rear wheel to get rid of the ticking noise. The passenger rear wheel is fine, so i'm guessing the ebrake inside the hub on the driver side was hitting the extended bolts but i don't know for sure..
Discussing Installed Spacers, now ticking noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
