Old Fri, Aug-19-2016, 12:00:07 AM   #61
Maxima SE
445 FTW
Maxima SE's Avatar
Reputation: 0 Maxima SE is on a distinguished road
Default Re: Torque Spec thread
anyone know the torque rating for the nut that fastens the strut mount to the strut
2005 6MT Phoenix Yellow///M3
Jump to top Maxima SE is offline   Reply With Quote
Old Fri, Aug-19-2016, 12:42:18 AM   #62
poms302
Reputation: 0 poms302 is on a distinguished road
47 ft lbs
Jump to top poms302 is offline   Reply With Quote
Old Fri, Aug-19-2016, 02:19:13 AM   #63
Maxima SE
445 FTW
Maxima SE's Avatar
thanks. what kind of fancy tool do i need to lock the nut to spec with these external hex head?
Old Fri, Aug-19-2016, 07:58:37 AM   #64
Flow
Flow's Avatar
France
An open wrench. Impossible to torque it down to spec with that.
Just use feeling.
2004 M3 TiAg / LSB SMG
Old Fri, Aug-19-2016, 12:03:37 PM   #65
Maxima SE
445 FTW
Maxima SE's Avatar
Can't even get a wrench in there. I'd hate to use an impact gun
Old Fri, Aug-19-2016, 12:42:45 PM   #66
cyberlando
cyberlando's Avatar
Default Re: Torque Spec Thread
Need a bigger overall picture of what your trying to tighten
Sent from my SM-N910F using Tapatalk
Engine:
Interior:
Suspension/Handling:
Old Fri, Aug-19-2016, 03:05:57 PM   #67
Flow
Flow's Avatar
France
Is the spring compressed ? You should be able to access it easily with an open wrench...
Old Tue, Aug-23-2016, 07:22:31 AM   #68
Flow
Flow's Avatar
France
Added some information about the differential.
Latest version : http://d.pr/f/1jtRu
Old Mon, Sep-19-2016, 04:38:18 PM   #69
bimmerfan08
bimmerfan08's Avatar
Was needing this for my latest DIY. Thanks again.
Old Sun, Sep-25-2016, 08:14:29 PM   #70
Malloy
Reputation: 0 Malloy is on a distinguished road
Flow: amazing. Thanks!!
Jump to top Malloy is offline   Reply With Quote
Discussing Torque Spec thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
