Old Thu, Jun-14-2018, 05:52:10 PM   #21
Default Re: Blackstone results not good
Originally Posted by Zzyzx85 View Post
I had a similar situation where 3 consecutive UOA was showing double the average copper, but little lead. I (and others on here) thought it had worn through the lead and was now in the copper.
I elected to do the rod bearings anyway, only to find the bearings were in perfect condition.
Do I regret doing it? No, because it gave me a peace of mind knowing the rod bearings being done. It also allowed me to take care of other things as well. It's expensive to do something but in my eyes, you can't be too cautious when it comes to the engine.
How have your numbers been since the replacement?
Trying to think of other places in the engine where copper could be coming from
Old Thu, Jun-14-2018, 06:40:54 PM   #22
Zzyzx85
Zzyzx85's Avatar
Reputation: 0 Zzyzx85 is on a distinguished road
Not yet. I'm still on the post-job oil. I plan on taking my next sample from the one after.
Could it be the mains? I'm hoping it isn't but this is a high mileage car (200k+). Always been on Castrol TWS.
Jump to top Zzyzx85 is offline   Reply With Quote
Old Thu, Jun-14-2018, 07:07:59 PM   #23
E30User
Reputation: 0 E30User is on a distinguished road
Originally Posted by TheSt|G View Post
What year? Only the early ones leave copper/lead when the bearings are going.
Does this mean later models, or a WPC treated set that was bought today will not show high amounts of copper/lead when they're going? If that's true, is there anything else in an oil analysis that shows clues of bearing wear?
Jump to top E30User is online now   Reply With Quote
Old Thu, Jun-14-2018, 07:14:15 PM   #24
He's talking about S65 bearings.
AFAIK, all OE S54 bearings are still lead/copper.
Old Thu, Jun-14-2018, 07:23:23 PM   #25
M3_Pilot
I had a similar case of having high copper and lead. My bearings were not as worn as the uoa depicted it to be when I replaced them. But the peace of mind was well worth it. I can dig up a thread I started to try and document wear numbers with bearing conditions. Or should I say how wear numbers do not always represent bearing condition.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Jump to top M3_Pilot is online now   Reply With Quote
Old Thu, Jun-14-2018, 07:27:57 PM   #26
bimmerfan08
bimmerfan08's Avatar
Ive completed two oil changes since replacing my rod bearings. Lead particle count dropped to 0 ppm but copper has remained around 7-8 ppm.
Old Thu, Jun-14-2018, 07:31:51 PM   #27
budbundy
Reputation: 0 budbundy is on a distinguished road
Valve guides or wrist pin bushings wear?
Jump to top budbundy is offline   Reply With Quote
Old Thu, Jun-14-2018, 10:20:35 PM   #28
The_Grumpy_Cat
The_Grumpy_Cat's Avatar
Reputation: 0 The_Grumpy_Cat is on a distinguished road
Just got my baseline report back as well reflecting not-so-good numbers. Not as bad as some others. They told me to listen for knocking and follow up in 3,000 miles This was my first oil change with the car so hopefully the next report will reflect something different.
Copper: 19
Lead: 36
| 2006 M3 ZCP | Silver Grey on Cinnamon | 6MT | 1 of 4 in North America | @SilberGrauM3 |
Jump to top The_Grumpy_Cat is online now   Reply With Quote
Old Thu, Jun-14-2018, 11:15:58 PM   #29
Kdubski
Kdubski's Avatar
I just sent out my 2nd oil change with my car @ 98,600 miles.
Lead: 38
Blackstone said to listen for knocking/low oil pressure and check back in 5,000 miles. I added LiquiMoly mos2 for the time being.
Old Thu, Jun-14-2018, 11:32:22 PM   #30
Texaz3
Hmm, I wonder if Blackstone has changed their testing method or something. All of a sudden, we have a lot of reports with bad numbers on lead and copper.
S54 is really not all that known for bearing wear aside from the early cars.
Discussing Blackstone results not good in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
