Old Fri, Jul-13-2018, 10:27:19 PM   #91
Steve M3
Default Re: Blackstone results not good
Yeah, I have S85 M6, so unfortunately, I have heard all the stories. My reports have been clean so far, though.
Honestly, I think the issue is somewhat blown out of proportion
, as I'm sure there are hundreds, if not thousands of these cars that are driven hard, and have not had oil testing done even once. So these owners pretty much don't know there is a possibility of bearing failure, they just keep driving it.
When I got my M3 and asked about oil analysis, there was a puzzled look on sellers' face. He had the car for a long time (over 85K, second owner). Which brings me back to my point - we get all worked up because of elevated lead in oil sample, and spend $$ to replace bearings, where some folks just keep driving their cars, oblivious to the fact, and nothing happens.
So, how much of this is a reason to worry - its for you to decide.
Truthfully, almost every single platform seems to have an issue or two that the Internet goes crazy over. I feel like some are blown out of proportion while others seem to be real threats. Like anything, you have to read as much as possible and see what you feel comfortable with. Don't think of it as playing the lottery so much as self-insuring against potential loss. In the end, it's only money and time either way you decide to go. Personally, I haven't replaced my bearings and don't feel overly worked up about it. Would I like for my engine to need to be replaced? Of course not, but I'm not going to lose sleep over the E46 boogeyman either. If I took everything I read to heart on here, I would be scared to even drive my car but in reality, driving it almost every single day has been the best thing I've ever done for it. Everything seems to work much better now than when it mostly sat around, go figure.
Jump to top Steve M3 is online now   Reply With Quote
Old Fri, Jul-13-2018, 10:33:30 PM   #92
EricSMG
40 something
Those look pretty bad! I wouldn’t feel bad about replacing them!
Ure almost thru to copper on most of them. I'd say u caught it in time
Excellent!
I'm at peace for sure. Picking it up tonight.
Old Fri, Jul-13-2018, 10:59:54 PM   #93
M3_Pilot
Those bearings look similar to mine when I replaced them last year with similar wear numbers. I'm done doing sample reports and am just going to replace the current bearings once they reach 60k miles.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Sat, Jul-14-2018, 03:36:50 AM   #94
Texaz3
Pretty bad? They look like bearing with 88K miles on them. I'd say normal wear. Could probably go for another 12-15K for sure. But like you said, I wouldn't feel bad about replacing them.
Old Sat, Jul-14-2018, 04:05:13 AM   #95
mrgizmo04
mrgizmo04's Avatar
I don't see where copper could be at 36ppm vs 8 avg from first post vs that pic. Lead at 49ppm vs 5avg, sure.
That pic def does not look bad. Top shells get more hammered so they have some more wear, but that's not bad condition.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Mon, Dec-24-2018, 01:08:23 AM   #96
yashajoon
Straight Six
yashajoon's Avatar
Reputation: 0 yashajoon is on a distinguished road
Any recommendations on what brand bearings to go with? Oem? BE? ACL?
Jump to top yashajoon is offline   Reply With Quote
Old Mon, Dec-24-2018, 03:27:23 PM   #97
Mcap
Reputation: 0 Mcap is on a distinguished road
Is the rod bearing replacement for all E46 M3 or just certain years? I have a 2004
Jump to top Mcap is offline   Reply With Quote
Old Mon, Dec-24-2018, 03:29:55 PM   #98
M3_Pilot
EVERY year has rod bearing wear.
@jet.m3
Old Mon, Dec-24-2018, 11:01:36 PM   #99
Mcap
😬 Ok thanks. I’ll look into getting that Blackstone Analysis. Will my local BMW dealership do it??
Old Mon, Dec-24-2018, 11:19:03 PM   #100
simon_c
Reputation: 0 simon_c is on a distinguished road
The dealership doesn't do this. You'll need to do an oil change and grab some of the oil and send it to Blackstone Labs (https://www.blackstone-labs.com). It's a really easy process.
2004 M3 - Alpine White | Impluse Cloth | 6MT
2002 M3 - Alpine White | Cinnamon | 6MT (past)
Jump to top simon_c is online now   Reply With Quote
Discussing Blackstone results not good in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
