Old Fri, May-19-2017, 05:34:25 PM   #1
Mpowerzz
Reputation: 0 Mpowerzz is on a distinguished road
Default Rear view mirror interchangeable
Is the rear view mirror interchangeable with other e46 m3. I have a 04 and I might get a 06 mirror if it could work.
Jump to top Mpowerzz is offline   Reply With Quote
Old Fri, May-19-2017, 05:41:01 PM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: Rear view mirror interchangeable
Yes.
And also any mirror from other models. They all use the same mount. The mirror bases have different styles, but all fit the hexagonal mount.
I have an EC/Compass/Alarm led mirror from a 2006 X5 in my 1998 M3.
Old Fri, May-19-2017, 05:49:14 PM   #3
I feel like we just had a thread like this. Does anyone search their issues anymore?
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav______________________JOURNAL
-Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped · SS V1 S pipe + 200 cell HFC · OE sect 2 · Supersprint Sport · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings
-TMS Camber & Subf plates · RE Street Trans Mounts · AKG poly SUB/DIFF · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · ss brake/clutch lines
-Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Fri, May-19-2017, 05:52:34 PM   #4
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
Yes, even my e36 mirror worked in my M3 for a while. Be sure that the donor mirror comes from your same body style (coupe or convertible). The keyless entry pickup for convertibles is in the mirror and for coupes it's in the driver's A-pillar IIRC. Therefore if you put a coupe mirror in a convertible, your keyless entry won't work.
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
Jump to top JaredMV is online now   Reply With Quote
Old Fri, May-19-2017, 05:58:20 PM   #5
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
should be fine as long as you're not swapping an oval mirror when you previously had a square mirror with assist. more info here
Tischer aka GetBmwParts
Old Fri, May-19-2017, 06:32:42 PM   #6
Move_Over
Reputation: 0 Move_Over is on a distinguished road
http://www.m3forum.net/m3forum/showt...=565116&page=6
Jump to top Move_Over is online now   Reply With Quote
Old Fri, May-19-2017, 09:46:20 PM   #7
WOLFN8TR
"MONEY"
WOLFN8TR's Avatar
I was just thinking the same thing.
Old Sat, May-20-2017, 08:57:18 AM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I guess "interchangeable" could mean different things, from will it fit to is it PnP?
Rewiring might apply. Always check the ETM/WDS and never just swap anything around, assuming it will be PnP.
The compass/led/ec(/gto) mirror does not exist with remote control electronics. The GTO board is taking that space, on non-GTO version, that space is empty.
I opened both mirrors and fitted the remote control circuit board of my E36 into the GTO board space. Then it took some rewiring of pins by comparing the wiring at both the base connector and pcb connectors and adding a control wire to get the led to funtion. It's controlled by the GM4 by connection it to ground. Since +12v is already going to the mirror, I used that to internally connect it to the led hot side. And since all other 9 pins were already taken.
EU E36's had the auto-dimm option and GM4 controlled remote control (keyless entry) so all wiring was already innplace, bar the led).
So yes, any mirror should fit, but do compare wiring diagrams.
Old Sat, May-20-2017, 12:40:18 PM   #9
Shadytype
Undercarriage checker
Reputation: 0 Shadytype is on a distinguished road
I have a 5 series mirror in mine. Plug and play, got homelink in it for my garage.
As a side benefit, you can actually see whts behind you, instead of that afterthought oval they put in there.
Jump to top Shadytype is offline   Reply With Quote
Discussing Rear view mirror interchangeable in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
