Old Fri, May-19-2017, 06:24:19 PM   #1
roman-dude
roman-dude's Avatar
Reputation: 0 roman-dude is on a distinguished road
Default paint chip repair ideas?
Have quite a few smaller chips on the hood that need to be addressed. Def don't want to be respraying it. Gravitating towards using Langka but am curious if anyone'd tried it or anything else.
thx
Jump to top roman-dude is offline   Reply With Quote
Old Fri, May-19-2017, 06:51:27 PM   #2
Default Re: paint chip repair ideas?
Dr Color chip makes it less noticeable since the color match is good, but the indentation of the chips will still be there. It helps.
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Euro Headers|sect 1 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Fri, May-19-2017, 08:36:47 PM   #3
lmtfi
lmtfi's Avatar
DR Colorchip. Read on their website and understand what it does and doesn't do.
Old Fri, May-19-2017, 10:10:00 PM   #4
icecream
Registered Apples
icecream's Avatar
I can't recommend Dr color chip. It is nothing special imo and the color match was horrible as well as adhesion. I emailed them and they were useless basically telling me that's just how it is. Save yourself the headache and buy an OEM touch up kit and use that.
Old Fri, May-19-2017, 10:11:14 PM   #5
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
I have used BMW touch up in the past with good results.
For me the key was only enough color to provide coverage, them build up slightly higher with clear and sand down with 3000 grit.
It is fussy, time consuming work.
Jump to top Jazzkat is offline   Reply With Quote
Old Fri, May-19-2017, 10:12:54 PM   #6
Bimmerchop
Reputation: 0 Bimmerchop is on a distinguished road
Rich | Flickr | Instagram | My AW/IR E46 M3 Journal
- AW/IR 6MT E46 M3
- JB/B 5MT E46 328i
- Ibis/Alcantara B8.5 A4 S-line
- Pearl Stg3+ B5 S4 (sold)
EURO.techniks
Jump to top Bimmerchop is offline   Reply With Quote
Old Sat, May-20-2017, 12:58:48 PM   #7
Kdubski
Kdubski's Avatar
Dr Color Chip
Old Sat, May-20-2017, 01:01:14 PM   #8
Paulo M
Dr colorchip is great imo. If your bumper is rashed to a point then you can blend it fairly well with dr colorchip. It won't be perfect but it'll make the chips much less noticeable.
If your bumper/hood is that bad, then don't be cheap and get a respect.
BREMBO BBS DIXIS
Old Sat, May-20-2017, 04:10:27 PM   #9
pachieh
Reputation: 0 pachieh is on a distinguished road
I just used Langka and it worked well for smaller chips. Deeper ones it didn't do much. I had them (this time around) make the touch up paint and it was a perfect match. I've used it with OEM paint from BMW previously and it worked fine.
I couldn't get enough of the front ones out with the bumper hood scratches and such, so just got a respray done for $600.
Jump to top pachieh is offline   Reply With Quote
Old Sat, May-20-2017, 05:30:26 PM   #10
m3nt0s
Reputation: 0 m3nt0s is on a distinguished road
Dr Color Chip works great as long as you prep the surface well. Deep chips unfortunately will require more work.
Jump to top m3nt0s is offline   Reply With Quote
Discussing paint chip repair ideas? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
