Old Wed, Mar-01-2017, 08:44:54 PM   #1
Newswartz
Newswartz's Avatar
Reputation: 0 Newswartz is on a distinguished road
Default Ordered AKG solid subframe mounts and they emailed me back......
After hrs of research it seems people are running aluminum subframe mounts with oem diff mounts and loving it. AKG says don't do it
Hello,
People move to aluminum bushings because they are not aware of how harsh they are on the chassis. The problem with aluminum is that it is unforgiving; you will get cracks, it is inherent with the use of the material - even if you are fully reinforced. With aluminum mounts and bushings, the car needs to be consistently inspected (with race cars this is before and after each event).
Also, it is very important to keep both subframe and diff bushings the same material hardness. If you have, for instance, aluminum subframe bushings and OEM diff bushings, the diff
will be flopping around and taking all the abuse, which can lead to problems.
For a street car, we would recommend the poly 95A subframe bushings (#SF469) with our 95A diff bushings (or at least a fresh set of OEM diff bushings). That coupled with the reinforcing you’ve already done should keep you in good shape.
Let me know if you have other questions.
Regards,
Lisa
AKG Motorsport
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=215618&dateline=15216  66489
· Dinan · Samco · RPI · Rogue · TTFS ·
· iForged · Mason · Turner · H&R · Hawk ·
· AKG · Redish · H&R · ST · StatusGruppe ·
Jump to top Newswartz is offline   Reply With Quote
Old Wed, Mar-01-2017, 08:47:42 PM   #2
FK
Default Re: Ordered AKG solid subframe mounts and they emailed me back......
She's not wrong. Solid subframe and diff bushings for a street car are ridiculous.
Old Wed, Mar-01-2017, 08:51:38 PM   #3
2manym3s
ballin
2manym3s's Avatar
Reputation: 0 2manym3s is on a distinguished road
I ran the poly mounts and honestly would stray away for a street car, do you drive the car at the limit frequently enough for it to justify the nvh increase?
Jump to top 2manym3s is offline   Reply With Quote
Old Wed, Mar-01-2017, 08:53:56 PM   #4
SimpleStaple
SimpleStaple's Avatar
Reputation: 0 SimpleStaple is on a distinguished road
I'm running full poly mounts in my car, but I am also used to it as all my other vehicles are poly mounts as well. The vibration is a non factor for me.
Jump to top SimpleStaple is offline   Reply With Quote
Old Wed, Mar-01-2017, 09:02:04 PM   #5
Newswartz
Newswartz's Avatar
I'm not trying to run solid diff mounts. Solid subframe and OEM diff
Old Wed, Mar-01-2017, 09:16:41 PM   #6
FK
Yea don't do that. I know some people will say that it's fine and that it's running stiff but there is no diff whine but for how long? If you are compromising in one area, you are benefiting in another. At no point can this be even. Look at this like a teeter totter.
Lady is correct, your diff will be getting roasted while your subframe is sandwiched against the mounts which won't move.
I went with the AKG 95D's all around for this reason, I considered doing the same thing a few months ago lol.
This is also all how you drive as well, if the car hardly sees miles then who cares lol
Old Wed, Mar-01-2017, 09:21:06 PM   #7
e46IX
e46IX's Avatar
Reputation: 0 e46IX is on a distinguished road
Uh-oh. I'm about to put in a set of TMS solid aluminum subframe bushings with all OEM differential bushings. I'll stick with my plan and see what happens.
Jump to top e46IX is offline   Reply With Quote
Old Wed, Mar-01-2017, 09:26:43 PM   #8
J05M3
Reputation: 0 J05M3 is on a distinguished road
Hello,
Regards,
Lisa
AKG Motorsport
This is contrary to the advice I have been given by respected members of this forum. I am sure one of them will chime in, but everything I have come across says going solid for subframe bushings is recommended to help PREVENT cracking due to the surface area of the solid bushing being greater against the RACP then the surface area of oem subframe bushings. Diff bushings are still recommended to go oem, but this putting greater strain on the diff does seem like it could be a concern.
Jump to top J05M3 is offline   Reply With Quote
Old Wed, Mar-01-2017, 09:33:21 PM   #9
FK
That's what I read into at first, then when I realized what kind of driving I typically do and how my road conditions were. I have a built diff so I'm not chancing it breaking over bushings. That's another reason why I went with the Reddish plates over TMS or w/e.
Old Wed, Mar-01-2017, 09:37:00 PM   #10
stack
The STIG
stack's Avatar
Reputation: 0 stack is on a distinguished road
Poland
I did AKG subframe bushings black
and also DIFF bushings
love the whine
04 E46 M3/ 95 E36 M3
Jump to top stack is offline   Reply With Quote
Discussing Ordered AKG solid subframe mounts and they emailed me back...... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
