Old Thu, Oct-12-2017, 10:28:55 PM   #1
arkow
Reputation: 0 arkow is on a distinguished road
Default Installed Spacers, now ticking noise
I got 15MM spacers (brand new) for my back wheels and 1 of them is a bit loose while on the hub, basically i can move it up and down a tiny bit, is this normal? now while driving i hear a ticking sound... there is no rubbing etc..
Thanks
Jump to top arkow is offline   Reply With Quote
Old Thu, Oct-12-2017, 10:31:57 PM   #2
rovert604
rovert604's Avatar
Default Re: Installed Spacers, now ticking noise
The movement should be totally tight around the lip of the axel. I have zero movement with my 12 and 15mm spacers. The ticking is most likely from an extended bolt(s) that are too long and they’re hitting the parking brake components behind the brake rotor hat. Pull out a bolt and see if you see some wearing on the corner. That’ll verify that. But your spacers should not wiggle around.
--Trevor in 604--
Vancouver, BC, Canada
Old Thu, Oct-12-2017, 10:58:31 PM   #3
m3vancity
Reputation: 0 m3vancity is on a distinguished road
dont tell me you bought ebay spacers and made a thread about it..
Jump to top m3vancity is online now   Reply With Quote
Old Thu, Oct-12-2017, 10:58:55 PM   #4
arkow
I checked the bolts and they don't show any signs of wear, they came with the Spacers, it was a package deal so the bolts should be the right size. I checked the other wheel and the spacer doesn't have any movement when is on the hub. I got a replacement spacer coming, hopefully that will resolve the issue.
Old Thu, Oct-12-2017, 10:59:30 PM   #5
rovert604
rovert604's Avatar
--Trevor in 604--
Old Thu, Oct-12-2017, 10:59:43 PM   #6
arkow
no, its not ebay, hehe..$100 for 2 15MM spacers with extended bolts..
Old Thu, Oct-12-2017, 11:30:18 PM   #7
m3vancity
mind sharing the brand?
Old Thu, Oct-12-2017, 11:34:45 PM   #8
Paulo M
Ticking sound is most likely from the bolts being too long. Happened to me before and you won't see any marks or anything when you remove for inspection. Try a shorter bolt.
BREMBO BBS DIXIS
Old Thu, Oct-12-2017, 11:45:07 PM   #9
arkow
They are ECS
Old Thu, Oct-12-2017, 11:45:58 PM   #10
arkow
Hmm I was under the assumption that when buying spacers with bolts they are the proper length, no?
Discussing Installed Spacers, now ticking noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
