Old Thu, Oct-12-2017, 12:16:33 AM   #11
aznniche
aznniche's Avatar
Default Re: Please don't tell me I need a new transmission or SMG pump... (vid inside)
Clutch related.. I had the same issue.
http://m3forum.net/m3forum/showthrea...ghlight=clutch
Old Thu, Oct-12-2017, 01:40:19 AM   #12
brichter
Unregistered Abuser
brichter's Avatar
Reputation: 0 brichter is on a distinguished road
Originally Posted by daytonaviolet View Post
read the codes. i have a similar issue and and mine is pointing towards gps.
How many miles on your car?
Mine died coming back from IMSA at LS (wouldn't shift into 3rd on the freeway), I popped off at the next exit, shut it off, restarted and it was fine the rest of the way over the hill.
2 days later it did the same thing, I swapped out the SMG relay (while an SJ cop was giving me stinkeye from across the intersection), and then it did it again the next day. Replaced the detent springs, one was bent, but it wouldn't relearn the shift positions. Stuffed a known good GPS in it and it relearned fine, so waiting on a new one now.
2002 AW M3
Jump to top brichter is offline   Reply With Quote
Old Thu, Oct-12-2017, 02:00:25 AM   #13
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
~ 210k
I already changed smg motor and accumulator. Ptech believes its the gps. So were changing it out as well as the compression spring. If that does not fix it .. dammit I have an actuator too.
Tischer aka GetBmwParts
Old Thu, Oct-12-2017, 02:59:58 AM   #14
RedM3/4
I'd do the springs - all of them - before I'd do anything else.
If a spring is bad it may not make position.
Normally springs failures don't give codes,
but if they've not been done, I'd sure do them before a sensor or an actuator.
ADS
~ 210k
Old Thu, Oct-12-2017, 04:58:05 AM   #15
brichter
Unregistered Abuser
brichter's Avatar
~ 210k
~150k on mine, autocross every month and 5-6 track days per year. Not sure if S5/S6 has anything to do with it, but that's where mine spends a lot of time.
2002 AW M3
Old Sun, Oct-15-2017, 05:43:35 PM   #16
MegamanDS
Haters keep hatin
MegamanDS's Avatar
Reputation: 0 MegamanDS is on a distinguished road
Armenia
So I swapped the salmon relay and the car now switched into gears and I was able to start it. But the code I got with my OBD was P1818. Looks like the SMG pump might be bad? Anyone else has had this code?
2005 SMG, Carbon Black Metallic with black interior, Cold Weather Package, Sports Package, Premium Sound, Navigation, 19" Rims, Bone Stock!
Jump to top MegamanDS is offline   Reply With Quote
Old Mon, Oct-16-2017, 01:08:11 AM   #17
jared212
Reputation: 0 jared212 is on a distinguished road
It is the gear positon sensor. OBD codes are useless, get INPA or bring it to someone who does.
Jump to top jared212 is offline   Reply With Quote
Discussing Please don't tell me I need a new transmission or SMG pump... (vid inside) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
