Old Wed, Oct-11-2017, 06:13:30 AM   #1
MegamanDS
Haters keep hatin
MegamanDS's Avatar
Reputation: 0 MegamanDS is on a distinguished road
Armenia
Default Please don't tell me I need a new transmission or SMG pump... (vid inside)
So for some reason, I can't start my car. It doesn't go into neutral at all. It just shows gear 1. I tried to press down on the brake harder (due to cold), I tried to jump it, I tried almost everything.
I can't even put it in neutral to roll it out of the garage for a tow truck to tow it. Any possible suggestions?
2005 SMG M3
105k miles
2005 SMG, Carbon Black Metallic with black interior, Cold Weather Package, Sports Package, Premium Sound, Navigation, 19" Rims, Bone Stock!
Jump to top MegamanDS is offline   Reply With Quote
Old Wed, Oct-11-2017, 12:04:56 PM   #2
WuBai
Five Spiced and Lovin' It
WuBai's Avatar
Default Re: Please don't tell me I need a new transmission or SMG pump... (vid inside)
First off, do you hear the pump priming? Have you checked your fluid level?
I had a leak in my actuator which gave me similar symptoms. When I had issues the actuator was $300, now it's over $1000!
Old Wed, Oct-11-2017, 02:41:00 PM   #3
Cha5en
Reputation: 0 Cha5en is on a distinguished road
Manual swap
/thread
Best of luck
Jump to top Cha5en is offline   Reply With Quote
Old Wed, Oct-11-2017, 05:11:26 PM   #4
03.5_m3_dinans2
03.5_m3_dinans2's Avatar
Reputation: 0 03.5_m3_dinans2 is on a distinguished road
I have the same issue. My car is at the shop right now. Pump primes and fluid level is at max.
Have you read the fault codes? You can use INPA to engage neutral.
Jump to top 03.5_m3_dinans2 is offline   Reply With Quote
Old Wed, Oct-11-2017, 06:32:29 PM   #5
MegamanDS
Haters keep hatin
MegamanDS's Avatar
Armenia
It is priming. I can hear the fluids moving. Usually I hear a 'click' before I can turn the key to start it to tell me it's ready after it primes. I don't hear that click anymore (obviously because I think the car won't go into neutral).
There are no fault codes that my OBS is pulling up. I haven't checked my fluid level though. I need to buy an INPA i guess to connect my laptop to the car to make it go into neutral for now
Old Wed, Oct-11-2017, 06:51:41 PM   #6
Toxic0n
You don't need to buy INPA but you do need a compatible OBD USB adapter. Check the coding and tuning section
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Wed, Oct-11-2017, 07:35:11 PM   #7
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
actually its $2300
https://www.ecstuning.com/b-genuine-...r/23412229789/
Tischer aka GetBmwParts
Old Wed, Oct-11-2017, 07:36:28 PM   #8
daytonaviolet
OEM CSL Whoore
read the codes. i have a similar issue and and mine is pointing towards gps.
Old Wed, Oct-11-2017, 10:50:42 PM   #9
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Got my 2006 about 3 years ago with only 30k miles. Now about 67k miles, and I've noticed in the past year that I have to press down on the brake pedal more heavily sometimes to get it to switch into neutral. Is there a sensor attached to the brake pedal that might be starting to fail? Wondering if that could be the OP's problem too...complete failure in his case.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Thu, Oct-12-2017, 01:01:44 AM   #10
RedM3/4
If you get no codes by a bmw specific reader/inpa, I'd expect something mechanical from the clutch or slave, since you're pump is running. TOB, pivot pin, etc.
ADS
Discussing Please don't tell me I need a new transmission or SMG pump... (vid inside) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
