Old Wed, Oct-11-2017, 06:55:42 PM   #21
mercedesc63
Reputation: 0 mercedesc63 is on a distinguished road
Default Re: 13.5F/13R & 19's - most comfortable suspension avail?
Originally Posted by aznbo187 View Post
With the popular 13.5 front & 13" rear suspension setup that's moderate, what is the most comfortable daily suspension setup with 19's? Prefer feedback from those with multiple setups on their cars as comfort can be very subjective.
Say, given a $3k budget. No track days, some weekend canyon carving duties.
My PSS10 on 18's on the lowest possible setting rear and .5 higher in front and softest setting 2 rides better than stock in the way that the dampening/rebound is crisp not bouncy like stock.
It would feel even better with stock sway bars/links I currently have GC f/r and it's very stiff.
Jump to top mercedesc63 is offline   Reply With Quote
Old Wed, Oct-11-2017, 07:10:17 PM   #22
Your car would ride and handle much better than it currently does if you raised it.
Old Wed, Oct-11-2017, 07:50:13 PM   #23
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
i'm all for comfort as i don't track much. i can only speak for bilsteins as i've had pss9 and now on pss10. it's been my DD for 13yrs and to me it's comfortable but depends on your settings. i believe my pss10's are set to 5fronts and 3rears (10 stiffest) with 13.5" fronts and 13.25" rears and it feels like oem.
Tischer aka GetBmwParts
Old Wed, Oct-11-2017, 10:37:36 PM   #24
whips333
whips333's Avatar
You guys are making me feel good about my TCK's again...thank you. I watched a couple videos from Shaikh from Fat Cat Motorsports last week and I think he wasn't too impressed with TCK.
Old Wed, Oct-11-2017, 11:47:04 PM   #25
EricSMG
40 something
Awesome thread. I must say that we've matured as a group over the years in that we can now discuss/compare Bilsteins, TCKs and Ohlins in a positive light.
Twentyseven and Obioban pretty much covered everything but I'll summarize having run all three myself:
1. TCKs = most comfortable with soft springs
2. PSS10s = razor sharp, racecar feel, firm and precise, excellent value, works best not super duper low
3. RT = most racecar-ish, firm and precise, very similar to the PSS10, works best really low, most expensive
From a behind-the-wheel standpoint it's quite remarkable how similar the PSS10 and Ohlins really are from the bump/rebound adjustment, beehive front springs, monotube design and the fact that they work with OE strut mounts (HUGE plus in my book). Either setup will be 'okay' comfort-wise but provide immense precision at speed. While both have a high-end feel, I would say that I like the RT slightly better except that it just wants to be too low for me. I don't like my cars low and the RT is meant to run low.
That said, the TCKs are definitely more comfortable as long as you keep the spring rates soft. Once the rates get up into the RT range I think they suck and would go monotube all day long. For best road manners do what Obioban said: 300 fronts with 400 rears and TMS street plates. The only thing I don't like about the TCKs is that they don't fit the OE strut mounts and that really bothers me on principle. It's laziness on their part.
Oh - I would never run anything KW on my cars - BTDT - it's junk in my book.
Point me to these videos?
He can do great things with Bilsteins and so it's easy to knock a Koni. From my point of view his real magic is in his Ripple Reducer where small bypass holes are drilled into the piston, thus reducing the initial 'stiction' of the shock, allowing it to absorb the really small vibratory type stuff - calms things in the cabin notably.
But the truth is that at the end of the day, a standard Koni has really nice valving curves for all around good street manners, and, chassis control. Bilstein differs in that they go super heavy on the rebound low/mid force and this is what gives them that 'locked down, precision' feel, but overall road comfort suffers as a result. What FatCat does, essentially, is bring the factory Billy curves more or less in-line with the Koni curve - soften the low/mid rebound a bit and you've a Koni.
All that said, the "problem" with a Koni (twin-tube), that cannot be fixed, is its tendency to develop hysteresis, easily seen in dyno curves. This is where the big bad monotubes are far better - hard driving, rapid damper movements. But for the street? Eh... mostly just rhetoric.
Old Thu, Oct-12-2017, 02:54:38 AM   #26
EricSMG
40 something
Edit: found the FCM video of the TCKs. He dynos an E36 M3 DA strut and also shows an AST DA strut, and, interestingly, a stock E46 M3 sachs strut (which I'm betting is mine as I regognize the graph and I doubt anyone else has sent their OE strut to him).
So, yeah - the DA 36M TCK strut is kinda funky on compression. It gets MEGA stiff and almost all of the adjustment happens at high speed rather than low speed, not really what you want. I will say that at the lower settings the compression curve looks pretty good with a nice blow off. It also has really, really bad hysteresis - you can hear the oil cavitating inside the strut at high speeds. This is most likely the result of the ultra low gas pressure at only 8lbs - this explains why a TCK strut falls into itself without a spring installed - I've wondered about that for over 10 yrs!!. An over the counter Koni has about 22lbs of gas, comparatively.
So, good with soft springs and low settings but not good cranked up/stiff springs, which has been my experience and the dyno confirms this.
Old Thu, Oct-12-2017, 05:28:38 AM   #27
AW///M3
Reputation: 0 AW///M3 is on a distinguished road
very informative thread! thanks!
TCK seems like the best option for a street car, but not being able to run stock front strut mounts makes it a deal breaker IMO. From my research all camber plates add NVH
Will stock front strut mounts and RE RSMs work with Bilstein Pss10's?
Jump to top AW///M3 is offline   Reply With Quote
Old Thu, Oct-12-2017, 06:59:07 AM   #28
whips333
whips333's Avatar
Yup, you definitely found the FCM video that I saw. Exactly how you explained it is how he explained it as well. I also saw a video when he talked about meeting up with you to set your car up for you as well. I love my TCKs SA but I want a sharper more racecar feel even though my car is my daily.
I had them set on half a turn from full soft and on 450/500 springs but it is way to comfortable for my driving style. I now have it set at half a turn from full hard and it feels a little more sharper to me although FCMs dyno shows otherwise. It's only been a week tho so I need more time behind the wheel with the new settings.
I plan on getting PSS10s when my TCK's finally give out but that might be a long time from now because like Obioban mentioned I have between 60-70,000 miles on them and they don't feel like they will need a rebuild anytime soon.
Old Thu, Oct-12-2017, 02:36:52 PM   #29
KS Golfer
Reputation: 0 KS Golfer is on a distinguished road
isn't there anybody that makes a shortened body (or remote res) that will do custom valving? i think you want the high-end internals and shortened body for a lowered street car, but get it valved for street use?
no?
Jump to top KS Golfer is offline   Reply With Quote
Old Thu, Oct-12-2017, 02:40:40 PM   #30
You can run stock e36 M3 strut hats on the e46 with the TCKs, if you find the camber plates on the market add too much NHV. TMS's street plates are pretty quiet, though.
Discussing 13.5F/13R & 19's - most comfortable suspension avail? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
