Old Tue, Oct-10-2017, 11:51:09 PM   #1
swimNdrive
Reputation: 0 swimNdrive is on a distinguished road
Default Help! Reinstalling Driveshaft to Diff
I recently decided to change my diff ratio to 3.92 on my E46 M3 and I'm currently at the point where I've already installed both side axles and am stuck trying to reconnect the driveshaft. Theres just not enough room to slide the driveshaft back into the differential. Anyone know what I may have done wrong or tips to help me install the driveshaft?
Thanks
Jump to top swimNdrive is offline   Reply With Quote
Old Tue, Oct-10-2017, 11:53:16 PM   #2
Msidd
Reputation: 0 Msidd is on a distinguished road
Default Re: Help! Reinstalling Driveshaft to Diff
Did you try to remove center support bearing?
Sent from my SM-G930T using Tapatalk
Jump to top Msidd is offline   Reply With Quote
Old Wed, Oct-11-2017, 12:04:17 AM   #3
swimNdrive
Yes, the central support bearing is out. I followed this DIY (http://forum.e46fanatics.com/showthread.php?t=521636)on removing everything out. I didn't have issues with taking the diff out, but I am having issues with reinstalling it.
Old Wed, Oct-11-2017, 12:08:01 AM   #4
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
I can't remember if I had to pull my guibo, but that seems like the easiest next step
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Wed, Oct-11-2017, 12:50:31 AM   #5
Good
@GOOD_M3
Good's Avatar
Thanks
I had the same issue. You will need another hand to pull down on the center of the driveshaft while you connect the end.
2006 M3 Competition | Silver Grey Metallic
Modifications:
- Complete SuperSprint Exhaust: Stepped V1 Headers, Race Catted Sec 1, Resonated X-Pipe Sec 2, Sport (Gen 2) Sec 3.
- Karbonius CSL Airbox (Alpha N) w/ Flap and Oil Catch Can
- KW V2 w/ Ground Control Camber Plates
Jump to top Good is online now   Reply With Quote
Old Wed, Oct-11-2017, 01:06:19 AM   #6
ThunderMoose
should be able to remove CSB and make it work. As mentioned, worse case remove from flex disk.
#67 2017 NASA TX TT3 Champion
Old Wed, Oct-11-2017, 01:26:45 AM   #7
mrgizmo04
mrgizmo04's Avatar
I had to install the diff side of driveshaft first, then guibo then csb. Somehow it wasn't working for me either doing the guibo end first.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Oct-11-2017, 02:01:21 AM   #8
swimNdrive
I ended up taking out both side axles again, loosened the front diff bushing bolt and that allowed me the room to wiggle the driveshaft back in.
Old Wed, Oct-11-2017, 02:03:46 AM   #9
Joshe46
Joshe46's Avatar
I was able to install it by myself while leaving everything else intact... weird!
Old Wed, Oct-11-2017, 02:03:55 AM   #10
11b4
11b4's Avatar
Losen the front diff bolt and wiggle the diff around.
EDIT: we both posted at the same time. Good job.
Last edited by 11b4; Wed, Oct-11-2017 at 02:04:51 AM. Reason: OP found a solution.
diy or instructions, driveshaft, e46m3
Discussing Help! Reinstalling Driveshaft to Diff in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
