Old Fri, Oct-13-2017, 12:54:35 AM   #21
WeekendM3
WeekendM3's Avatar
Reputation: 0 WeekendM3 is on a distinguished road
Default Re: CSL intake question
CSL intake sound is addicting.
Like the CSL gurus here said, don't worry too much about the splicing etc, you don't have to if you don't want to. You can order the "contacts for DME" and all other associated parts from the list in the picture below (pictures / instructions borrowed from M3forum and it's awesome members).
One piece of advice though, you'll be 90% there so please do yourself a favor and have a working flap. The sound / emotion generated when the flap opens at 3,500 RPM is truly something else. Watching the flap open when you're showing it to another enthusiast / friends etc has a certain cool factor to it, all the while knowing you made it all happen with your DIY install!
Here are the two sheets I used for my initial install and then to trouble shoot my map sensor wiring since I had wired the GM sensor from TTFS improperly the first time around.
A little eye candy
SOLD - 11/24/2017
2003 - Alpine White / Imola Red M3 Coupe 6MT * Factory Sunroof Delete * Manual Seats * Xenon * HK * Dinan Exhaust * Karbonius CSL Airbox * TTFS Tune * OE Operational CSL Flap / Snorkel *
Jump to top WeekendM3 is offline   Reply With Quote
Old Fri, Oct-13-2017, 05:27:01 PM   #22
Brett72586
Reputation: 0 Brett72586 is on a distinguished road
ordering/collecting of parts has officially begun. My worst fear is that im going to do this and get messed up on the coding/loading/wiring part and then ill be stuck with a use m3 until either A. can figure it out or B. go back to stock and cry myself asleep for many nights knowing i just wasted a ton of money but 10/10 worth the risk for that noise
Jump to top Brett72586 is offline   Reply With Quote
Old Fri, Oct-13-2017, 08:54:54 PM   #23
WeekendM3
WeekendM3's Avatar
You'll be fine. If you get stuck just do a detailed post on the forum as I did and you're guaranteed to get a valid answer as the senior members start chiming in. I forgot to add this image of my order, it's the sockets for the IAT sensor and the flap motor (both use the 2 wire socket - ecs item # 31215 - quantity needed 2) and the socket for the flap position sensor (this is the 3 wire socket - ecs item # 31208 - quantity needed 1).
Good luck man
SOLD - 11/24/2017
Old Tue, Oct-24-2017, 08:41:22 PM   #24
Brett72586
Still ordering some cheaper parts. My daily driver that ive owned for 10 years (e46 325ci) just started making a noise and needs a new drive shaft (stupid u joints). Also, the m3 SMG (i assume) is making a groaning noise but stops when you start moving (clutch is engaged?) or it shifts into gear (IE neutral to R or 1st). The noise only stops during the actuation.
Until both are fixed i am shelving this. New drive shaft for DD will be here this week and next week bmw is doing diag on the m3.
Like i said, still ordering the cheaper parts and i do appreciate people putting their orders up for me
Old Sat, Nov-04-2017, 01:57:23 PM   #25
Brett72586
Well, according to BMW i need a new transmission, so everything is on hold until i can get a second opinion. Might start a second thread to help diagnose the noise as well.
Discussing CSL intake question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
