Old Thu, Oct-12-2017, 01:39:35 AM   #11
lippstuh
Reputation: 0 lippstuh is on a distinguished road
Default Re: CSL intake question
If you're not planning on running the flap, you don't need a real CSL DME (technically you don't need one even with a flap, but I digress) - a normal MSS54HP will work fine with a MAP sensor if you flash it with the CSL software.
What if one has MSS54? Would we need to buy a MSS54HP DME?
/// 2002 Jet Black 6MT Cinnamon
Mods Evolve Eventuri JIC Cross/ZMS RS coilovers Square OE Style 67 18s Michelin Pilot Sport 4S OE CSL trunk OE LED taillights Llumar Air 80 Tint
Jump to top lippstuh is offline   Reply With Quote
Old Thu, Oct-12-2017, 02:24:47 AM   #12
I think you do.
Terra, if we don't want a flap, do we have to do the h-bridge solder thing? Or is that a thing to make the map sensor work?
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav no xenon no anything JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped SS V1 S pipe + 200 cell HFC OE sect 2 SS Sport BMW Motorsport 4.10 Besian RE pullies/fan delete WPC rod bearings TMS Camber & Subf plates RE Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Oct-12-2017, 02:29:17 AM   #13
Brian N
wubalubadubdub
Brian N's Avatar
I don't think you do. When I researched its only done if you wanted the flap.
-My Journal-
Old Thu, Oct-12-2017, 02:32:22 AM   #14
You can solder the larger flash chips to the DME and run the CSL software with that. Though my preference is to have a real HP.
Edit: Forgot to mention, there are two resistors that need to be changed if using a MAP sensor on a non-HP.
I think you do.
H-bridge is only needed if using a flap.
Old Thu, Oct-12-2017, 04:26:16 AM   #15
Thank you Terra, so again, in non-computer person talk, if I have a MSS54HP (11/2003 build), I could simply load the CSL engine management and get a map sensor and csl IAT and take care of the vent lines?
Thank you again
Old Thu, Oct-12-2017, 02:03:17 PM   #16
Thank you again
Pretty much, though loading the CSL software will either require MSSFlasher (which from what I understand is down at the moment) or a BDM flash.
Doesn't necessarily have to be CSL IAT, it's pretty easy to rescale the curve for other sensors.
Old Thu, Oct-12-2017, 10:32:15 PM   #17
Brett72586
Reputation: 0 Brett72586 is on a distinguished road
Okay,
So here is what i got so far. I am trying to make this as easy as pie. Trying for mostly plug and play or something already modded and sent to me
CSL instake with karbonius
Map sensor - either
https://store.langracing.com/s54-map...fi-conversion/
or
http://tuningtechfs.com/ttfs-e46-m3-...nd-map-sensor/
I am iffy one splicing wires because thats permanent but when i hear the noise of the CSL air box i just start drooling.
DME
http://www.ebay.com/itm/2004-BMW-E46...1Z0wZA&vxp=mtr
Relocate brake booster line with appropriate tubing
Extend crankcase vent hose with appropriate tubing
Add-on which are not essential but (somewhat) recommended:
OE CSL Brake Booster Valve
OE CSL Vent Hose
Do these two parts above take care of the "appropriate tubing" part of this or is there an OE part i can get?
Jump to top Brett72586 is offline   Reply With Quote
Old Thu, Oct-12-2017, 11:05:46 PM   #18
Bimmerman325i
Beardface McMountainMan
Bimmerman325i's Avatar
You don't have to splice any wires at all.
You can instead de-pin the connector at the DME. That way you're not irreparably altering the OE harness. You use a pick to remove the original IAT/MAF wires from the DME connector, making them unused and unpowered. You then install your new MAP and IAT wires in their place in the DME connector.
It sounds more complicated than it actually is-- takes less time than cutting and splicing, is much cleaner for troubleshooting, and can be reverted back to original condition if/when that matters.
1998 BMW M3/4/5 -- DD rev1
Old Thu, Oct-12-2017, 11:47:59 PM   #19
Okay,
Map sensor - either
or
DME
OE CSL Vent Hose
I wouldn't worry about splicing wires. You can get a complete stock harness pretty cheap, and it's surprisingly simple to replace when you've got the airbox off anyway. So if you do decide to go back to stock, you can always just replace the engine harness
Those two parts do take care of the "appropriate tubing"
Old Fri, Oct-13-2017, 12:42:48 AM   #20
WeekendM3
WeekendM3's Avatar
Reputation: 0 WeekendM3 is on a distinguished road
CSL intake sound is addicting.
Like the CSL gurus here said, don't worry too much about the splicing etc, you don't have to if you don't want to. You can order the "connectors for DME" and all other associated parts from the list in the picture below (pictures / instructions borrowed from M3forum and it's awesome members).
One piece of advice though, you'll be 90% there so please do yourself a favor and have a working flap. The sound / emotion generated when the flap opens at 3,500 RPM is truly something else. Watching the flap open when you're showing your family / friends etc has a c
SOLD - 11/24/2017
2003 - Alpine White / Imola Red M3 Coupe 6MT * Factory Sunroof Delete * Manual Seats * Xenon * HK * Dinan Exhaust * Karbonius CSL Airbox * TTFS Tune * OE Operational CSL Flap / Snorkel *
Jump to top WeekendM3 is offline   Reply With Quote
Discussing CSL intake question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
