Old Tue, Oct-10-2017, 08:41:09 PM   #1
Brett72586
Reputation: 0 Brett72586 is on a distinguished road
Default CSL intake question
Hello,
Long time lurker, even long time owner of the E46 chassis, new to me e46 m3.
I recently just got a 2005 m3. I plan on going with 288/280 schrick cams and a karbonius CSL intake this winter. I know there are a lot of DIYs out there but with the e46 chassis getting old there is A LOT of information out there. Some of it pertains to what i am asking and some of it does not, so i am hoping to stop wasting time on the googles. I know some people just buy the air box, modify the wiring harness, get the alpha N and call it a day.
Others though get the CSL DME, CSL wiring harness, CSL fuel rails, etc.
I think I plan on going CSL DME, harness, and fuel rails but i cant find out why people do get the fuel rails. I understand the DME part and the wiring harness part. I am just curious on the fuel rails and if there are other "OE" parts i should consider. I want to do this right the first time around without regrets or having that thought in the back of my head that it isnt done correctly. Yes, I know ECS has a CSL package for 10k, but cmon...
Some stats about said new M3:
2005 mystic blue with 74,000 miles
SMG
19" apex wheels
all new bushing though out drive line/suspension (upkeep in maintenance in general)
ZCP package upgrade (brakes/steering rack)
TMS power pullies
AFE Stage 2 CAI
status gruppe headers, OEM Euro 200 cell cat, status gruppe scza muffler
TMS rear adjust trailing/control arms
alcentera steering wheel
stainless steel brake lines
Evolve tune
OE euro front bumper
new OE shocks/struts with eiback pro springs (debating on going coil overs over the winter)
This winter i will be accomplishing rod bearing and schrick cams with two different tunes for premium and 100 octane.
Hoping to accomplish CSL intake and OE CSL trunk this winter as well. Maybe a lip of some sort?
thanks for the advice - can post pictures if desired
Jump to top Brett72586 is offline   Reply With Quote
Old Tue, Oct-10-2017, 09:02:07 PM   #2
usdmej
Default Re: CSL intake question
Originally Posted by Brett72586 View Post
Hello,
get used to blindly spending money
there's a huge thread on CSL airboxes with driveability issues. i understand people piecing together a carbon airbox setup when good deals come up, but i've no idea how people that actually do the research still go through with it
Jump to top usdmej is offline   Reply With Quote
Old Tue, Oct-10-2017, 09:21:33 PM   #3
Nobody gets the CSL fuel rail (which is the same as the M3 fuel rail). Some of us got the CSL idle rail to use the CSL map sensor. Not much point in that anymore though since the OE MAP sensor is discontinued (so you may as well just use any aftermarket sensor and T-off the brake booster).
I wouldn't bother with the wiring harness either. Since you'll have to use a custom map sensor, you'll be modifying it (or building an adapter) anyway, and otherwise the wiring differences are minimal. And unless you get it cheap, I'd just modify a regular MSS54HP to CSL spec rather than buying a real CSL DME. Having examined both, there's no physical or electrical difference beyond the flap driver.
Those drivability issues are largely exaggerated and mostly a result of people looking for issues after the conversion (stock setup isn't 100% perfect either, especially at low RPMs). If you hit the throttle in the right way while Saturn and Mars are aligned with the Earth, then you can induce a very minor hiccup, and some minor tuning can minimize / eliminate said hiccup. Otherwise there are no drivability issues to speak of - going 3 years now.
Old Tue, Oct-10-2017, 09:58:28 PM   #4
Karbon
Back to Basics
Karbon's Avatar
Reputation: 0 Karbon is on a distinguished road
+1 to everything Terra stated above.
Here are the essentials and the best setup in terms of price and quality:
Karbonius CSL Airbox (or Streamline depending on how it turns out)
ITG CSL Filter
MSS54HP 2003.5-2006 (loaded with CSL software)
OE CSL Temp Sensor
AEM MAP sensor (spliced in)
Wiring for MAP sensor
Relocate brake booster line with appropriate tubing
Extend crankcase vent hose with appropriate tubing
Add-on which are not essential but (somewhat) recommended:
OE CSL Control Unit + wiring
OE CSL Brake Booster Valve
OE CSL Vent Hose
2003.5-2004 are the best cars to have for the conversion since they should have the MSS54HP DME and the 2001-2003 intake boots.
Jump to top Karbon is offline   Reply With Quote
Old Tue, Oct-10-2017, 10:12:20 PM   #5
Brett72586
I was wondering if you were still around. I have a ton of your DIYs saved for m3/general E46 stuff. Top notch stuff. I have actually thought about making an account long time ago just to say thanks for helping the bmw/e46 community the way you do. I dont plan on getting the flap but i thought the DME was needed to avoid going alpha N. I have read huge threads saying 'YAY Alpha is the Shiz...or Alpha is complete garbage. what route did you go? You dont happen to have a CSL diy you made do you?! lol
Do you have cams by chance? how did the butt dyno feel once you finished it?
ITG CSL Filter
OE CSL Temp Sensor
OE CSL Vent Hose
Thanks for the info. This is basically what i was looking for. The nitty and gritty. Do you know where i can get the MSS54HP loaded with CSL software? i am going to start looking up the parts to buy/diys for them. I have a feeling this is going to be a multiple DIY use for things.
Old Tue, Oct-10-2017, 10:19:23 PM   #6
usdmej
i wish this were true, but my experience and others have been different. I've actually contacted you and also some big tuning names here for help and have been either ignored or turned down at some point in time for help on the matter.
i guess in the grand scheme of things, if you're able/willing to figure out the install/coding/troubleshooting on your own and have a second car . . . hell i still wouldnt recommend going through with it
Old Tue, Oct-10-2017, 10:27:10 PM   #7
Karbon
Back to Basics
Karbon's Avatar
Someone in the coding section could probably help you load it if you already have a MSS54HP.
Edit: Actually another forum member made a tool for flashing software, but the website is down: msstuning.com
Old Wed, Oct-11-2017, 06:50:57 PM   #8
Brett72586
MSS Flasher - YouTube
So, follow up question.
Lets say this site does come back one day and i can load the "csl" software. I also show it has alpha n. Does that mean i can literally just load/install the software, reload my evovle tune, and be done with the "programming" side of things?
Or does evovle need to update their tune (the cams will already be updated by this point in the evovle tune)
Old Wed, Oct-11-2017, 07:42:33 PM   #9
usdmej
the big name tuners will have their own proprietary software so you won't need MSS flasher to read/load tunes (although it appears that MSS has turned into a for profit tuning company under a different name which explains why the website is gone)
Old Thu, Oct-12-2017, 01:29:12 AM   #10
I'm using the OE MAP sensor with lightly modified CSL software modifications mostly come down to 6MT and disabled off knock adaptions (the car will still react to knock, it just won't store long term adaptions for it). Car drives pretty good. MAP sensor improves low throttle behavior in particular. Power is definitely up, which I attribute to the CSL being a bit more aggressively tuned. I don't have cams. I'd consider them if I can get a good price, but right now making more power isn't a priority.
If you're not planning on running the flap, you don't need a real CSL DME (technically you don't need one even with a flap, but I digress) - a normal MSS54HP will work fine with a MAP sensor if you flash it with the CSL software.
Discussing CSL intake question in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
