Go Back   BMW M3 (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E46 M3 (2001-2006)
Old Thu, Oct-12-2017, 08:27:07 PM   #21
Your mom goes to college
T3AMFiSh's Avatar
Default Re: Which Exhaust?
i must be the only one then that thinks the BB sounds "twangy"...
Old Thu, Oct-12-2017, 08:32:12 PM   #22
Good's Avatar
Originally Posted by Dr M3an M3 View Post
Hard to say from the pictures posted of the headers, but they are definitely not the Stepped V1 nor the Stepped V2. You can clearly see in the photographs that there is no 'stepping' of pipe size like shown in Obioban's post. This leaves just one other offering that Supersprint makes, the NON-stepped 'Tubolare' header. If I had to guess, I would assume that these are either Supersprint Non-stepped headers or a copy.
Some things that stand out to me:
-As Obioban mentioned, the metal used just does not look like the typical steel used by Supersprint. Especially with the corrosion on these on the collector. Maybe this was an older "earlier" version?
-also there should be a Supersprint logo engraving present. To my knowledge, all their products have this. Ex (SS Stepped V1):
-You likely will also see lines/impressions in the metal from their mandrel bending machine...but likely this is not unique to Supersprint and can be found on other headers perhaps (depending on what was used to bend the pipes).
-The actual collector, and sensor bungs also look different to me (especially the EGT bung location), as do the welds for those items. Ex:
This is more typical of what Supersprint headers look like after they have been heat cycled (not the ceramic coated ones also pictured):
The only thing that reminds me of Supersprint is the serial number plate (which I think corresponds to the jig used).
For ex (SSV1):
The actual primary piping looks consistent with the Non-stepped Supersprint headers (keeping in mind that this a very highly copied design):
Ex (Non-stepped V1):
*also note that while these look nearly the same, the sensor bungs are slightly different as is the serial number is also different.
Ex: (Non-Stepped V2)
I'd say that these are either an older set of Supersprint Non-Stepped headers or a copy. The serial number doesn't match up to any of the numbers I have found on other non-stepped Supersprint headers.
here is a good thread asking essentially the same question on a similar looking set of headers:
If it interests you, I'd call a representative of Supersprint or Supersprint directly to get a definitive answer. Supersprint non-stepped and Euro headers are far and away the most copied designs.
Thanks all, will try to get in contact with them this weekend.
2006 BMW M3 Competition Package
StatusGruppe CSL Trunk, JL Motoring 1-Piece Lip
Active Autowerke Headers, Stage 3 B-Spec Tune,
Powerflex Poly FCAB & RTAB, H&R Sport Springs
Macht Schnell Stage 1 Elbow & Filter.
Mods: Active Autowerke Headers, Euro Section 1, Statusgruppe Resonated X-pipe Section 2, Supersprint Sport, Stage 3 B-Spec Tune, Powerflex Control/Trailing Arms, H&R Sport, Macht Schnell Elbow/filter, Xtrons Headunit.
Major Maintenance: WPC Rod Bearings, Cooling System Refresh, Subframe Bushings & Reinforcement, Differential rebuild.
Old Thu, Oct-12-2017, 10:50:50 PM   #23
bmw m3 s50
Why So Serious ? :}
bmw m3 s50's Avatar
Reputation: 0 bmw m3 s50 is on a distinguished road
Yea, supersprint headers have gone through a lot of evolutions. I can say for a fact that my v2 non stepped headers to not have a horse or supersprint logo on them. I am not sure if they have the number plate either. I do remember being on the phone with super sprint and sending photos to verify the headers in order to get confirmation that they were real. This was back in 2008 before the stepped headers and when all the replicas were coming to market. I do remember distinctly that some of the older NON stepped headers had a number plate on them some did not.
Now and days all headers are basically copies of those headers so in the end it's all the same unless you need the supersprint name.
Also reading the one post, I remember that exactly what the number plate is. It corresponds with the jig used. This was what I was told when talking to supersprint. It's coming back to me. Damn this was ages ago I feel. Also the line impressions were how they figured out mine were real. Those impressions were from the jig.
Jump to top bmw m3 s50 is offline   Reply With Quote
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd. and is in no way sponsored, endorsed or affiliated by or with BMW NA / BMW AG or any of it's subsidiaries or vendors.
Copyright 1999-2017
Discussing Which Exhaust? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
Total Produced: 45,000+ - Years Produced: 2001 to 2006. at BMW M3 (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
