Old Mon, Oct-09-2017, 07:06:06 PM   #11
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default Re: Front bumper alignment
first, what type of bumper carrier do you have? aluminum or kevlar?
Tischer aka GetBmwParts
Old Mon, Oct-09-2017, 07:15:15 PM   #12
02_LSB
Jump to top 02_LSB is offline   Reply With Quote
Old Mon, Oct-09-2017, 07:27:22 PM   #13
daytonaviolet
OEM CSL Whoore
looks like you have aluminum carrier. this means there is no front/back adjustment because the bumper is held in place with ASA bolts. can you remove the fender liner (the part that attaches to the bumper often times restricts the placement of the bumper). let's see if the bumper aligns on the side without the fender liner.
Old Mon, Oct-09-2017, 07:30:33 PM   #14
02_LSB
Ok. Thank you.
Give me a couple of minutes. I just put in a fan, need to wrap up a few things here, including getting rid of halos.
Old Mon, Oct-09-2017, 07:59:58 PM   #15
daytonaviolet
OEM CSL Whoore
Originally Posted by 02_LSB View Post
Ok. Thank you.
sure.. im just making sure the fender liners are not restricting the alignment.
Old Mon, Oct-09-2017, 08:03:48 PM   #16
02_LSB
Default Front bumper alignment
Two bolts removed from the plastic mount. I'm seeing this
Old Mon, Oct-09-2017, 08:10:07 PM   #17
02_LSB
No change in movement. Half tempted to remove the bumper cover and look at the aluminum bumper and see about adjusting it inward a bit
Old Mon, Oct-09-2017, 08:57:11 PM   #18
daytonaviolet
OEM CSL Whoore
How about a side view? I wonder if something was bent ? If you do remove the bumper, you can also check the rivets in the aluminum carrier. These rivets hold the bumper cover to the aluminum carrier.
Old Mon, Oct-09-2017, 10:08:09 PM   #19
02_LSB
Ran out of time. It appears I need allocate 3 - 4 hours for the bumper. I thought it would be an easy adjustment.
Old Mon, Oct-09-2017, 10:25:55 PM   #20
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Been there. I spent 4 hours taking the bumper off, putting new bumper guides on and came out with the same issue. I have the aluminum carrier as well.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Discussing Front bumper alignment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
