Old Fri, Sep-29-2017, 03:44:12 PM   #11
M3n00b
M3n00b's Avatar
North Korea
Default Re: E36 m3 5.5k rpm loss of power when hot
Originally Posted by EurAutoJunction View Post
Bad dme perhaps? If it was a tune I need, wouldn't the consistency of power be the same on all temperature?
Not bad, just confused, air temperature affects it's density and the computer is confused at higher rpms when hot. It's programmed for thinner runners.
-tapa
Old Fri, Sep-29-2017, 04:35:42 PM   #12
EurAutoJunction
Reputation: 0 EurAutoJunction is on a distinguished road
-tapa
Hopefully that is the case. The day I was out there, it wasn't that hot (89 degree with 18% humidity). I just took it out for a spin and it diff has power all the way til redline in 1st and 2nd. The lag up high is diff gone since the clutch fan is gone. I will try it in the higher gears later when the temp goes up a bit.
17 golf gti DD
97 m3 WEEKEND TOY
89 325i SOLD
87 325is SOLD
95 525i TOTALED
87 325e SOLD
91 318is SOLD
90 240sx coupe SOLD
89 240sx hatchback SOLD
Jump to top EurAutoJunction is offline   Reply With Quote
Old Fri, Sep-29-2017, 05:21:34 PM   #13
Answer the trap mph question please.
Old Fri, Sep-29-2017, 06:45:18 PM   #14
EurAutoJunction
15.1/91 mph, 14.5/95 mph, 14.8/92 mph
17 golf gti DD
97 m3 WEEKEND TOY
89 325i SOLD
87 325is SOLD
95 525i TOTALED
87 325e SOLD
91 318is SOLD
90 240sx coupe SOLD
Old Fri, Sep-29-2017, 07:13:13 PM   #15
Yikes, yeah you have a motor issue for sure. You should be hitting 98-101 with minor mods and stock weight.
Old Fri, Sep-29-2017, 07:18:52 PM   #16
The 14.5 at 95 is OK for a stock car, but the other traps are low. I think you are right that you are down on some power on the top end. If the clutch fan was locked up and spinning at engine rpm, that could have an effect if I am correct in understanding that the viscous coupling inside allows slippage at high rpm in addition to providing temperature related partial lockup.
With your mods on a sorted out car, even with no tune, you should be around 100 mph.
Hopefully you will go back to the track with the electric fan and tell us how it goes.
I am stuck in the low to mid 11s in the low 130s for a couple of years, but have not run this year. Broke enough stuff that I need a rest. I even break stuff just driving on the street. Diff output stubs, driveshafts, clutches, transmissions. And a totally-my-error at the strip mis-shift cost me a cylinder head and some valves. But I rebuilt everything except the trans stronger. On my 3rd ZF320. They don't like 500-600 lbs rwtq. Might try a 420G next or maybe a T56 Magnum, but the T56 with bell housing adapter is a $4k project. It does get rid of the sloppy shifter, though, since the shifter comes out of the back of the trans rather than connecting to it by a linkage.
Old Fri, Sep-29-2017, 08:57:51 PM   #17
englishtom1596q
englishtom1596q's Avatar
Bad knock sensors
Jump to top englishtom1596q is online now   Reply With Quote
Old Tue, Oct-03-2017, 03:36:50 PM   #18
abcurran
Originally Posted by englishtom1596q View Post
Bad knock sensors
Or cam sensors. It sounds like something is retarding the timing above 5.5K RPM on the "hot" runs. I wish I had an explanation for you did manage the 14.5 sec. run, though. Maybe the Vanos solenoid isn't opening/functioning within its complete range?
I don't think a 30 min cool down period between runs would really lower engine temps to the point where you could call the second run a "cold" run. The 30 min drive to the track and the WOT run would/should have oil and water temps at their operational temperatures. It would take much longer than 30 mins to lower water temps to cold. Oil temp is more varied, but maybe I'm wrong.
The fan clutch is an easy and cheap to replace.
. In my case, I didn't even need the water pump pulley holder. I was able to fit long screw driver between the bolts.
Old Tue, Oct-03-2017, 05:24:18 PM   #19
betrezra
For proper diagnosis you need some data..... there are cheap OBD connector loggers so can can log the following VS Time on your runs:
1 - IAT
2 - Timing
3 - RPM
4 - coolant temps
5 - st and lt fuel trims (assuming this vintage has such things)
6 - O2 sensor voltage
Add'l bonus if you add an O2 sensor... and can track AFR real-time.
Add'l bonus if you add a fuel pressure sensor... and track real-time.
Add'l bonus if you can pull some codes for other potential faulty sensors.
Will tell you:
* fuel delivery issue?
* AFR, IE tune issue?
* timing / tune issue?
etc.. etc...
Other causes of lost of MPH @ Track:
1. State of repair..... dirty airfilter? old sp plugs? gapped wrong? bad fuel?
2. poor Air.... DA..... you can look this up. Makes a big diff even on na cars.
good luck with your search for powa!
E36M3 5spd
360Modena 6spd
Old Tue, Oct-03-2017, 06:18:42 PM   #20
I think the vanos retards at high rpm to add top end power. This is also the default. If vanos does not work, it typically retards and the lack of 1000-5000 rpm advance softens power in that range. Top end power would be unaffected.
Discussing E36 m3 5.5k rpm loss of power when hot in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
