Old Thu, Sep-28-2017, 10:02:01 PM   #21
aeronaut
aeronaut's Avatar
Reputation: 0 aeronaut is on a distinguished road
Default Re: How high is too high with water temp on the track?
Just FYI, I had a Mishimoto rad, and a Motion Motorsports underpanel. The MM baffling would not fit properly with that combo. I never made any custom baffling. I saw about 225-230deg at an event a few months ago...OEM gauge got up to about 3/4.
So I replaced my 5 y/o mishi rad with the Z3 rad, installed the MM baffle, and all is good. The following weekend under exactly same track conditions, water temp always well under 220.
Jump to top aeronaut is offline   Reply With Quote
Old Thu, Sep-28-2017, 11:59:23 PM   #22
nholmes
Track Junky
nholmes's Avatar
I have the MM undertray, Z3M radiator, hood vents and all the other stuff the OP posted.
I coded out the dead zone for the temp gauge in my cluster module to get a more accurate reading when pushing the car.
Factory dead zone is 176*-216*F
I haven't had an issue yet. I will say that I think the best of all the mods was the three core radiator. That extra pass through is totally worth it IMO. Cheap too! I think the Behr OEM radiators are like $400-$500?
Follow my build thread here:
Old Fri, Sep-29-2017, 12:12:21 AM   #23
omairtheman1
BEHR OEM S54 Z3M Radiator is like $160ish and OE with the BMW stamp is around $330ish.
Old Fri, Sep-29-2017, 05:38:54 AM   #24
nholmes
Track Junky
nholmes's Avatar
EDIT: I went back and looked at my receipts. Looks like I paid $150.
Old Fri, Sep-29-2017, 11:09:20 PM   #25
DasBlitzAuto
Reputation: 0 DasBlitzAuto is on a distinguished road
Originally Posted by jayjaya29 View Post
Just had an overheat situation with my 95 m3. Currently doing the head gasket.
I do have a Mishimoto radiator...only had issues when pushing it hard on the track.
Overheat happens at end of video at 10:40 in
Lime Rock Park, NASA NE, HPDE 4, 8-26-17 - YouTube
Small world Jayjaya we were there at limerock when this happened, my friends estoril is the one that blew the radiator the same day. Did your head gasket actually fail?
Looks like 2 more for the S54 Rad, best bang for the buck it seems. Although I still am considering Zionsville.
1997 Estorilblau E36 M3
TCKR DA Suspension - Turner Sways - Active Autowerke Intake/Exhaust - 17x9 ARC8 - Hankook RS4 245/40/17 Square - UUC EVO Short Shifter - Kirk Rollbar - Sparco Evo 2s - MOMO Monte Carlo Wheel - Motion Motorsport Underpanel
Jump to top DasBlitzAuto is offline   Reply With Quote
Old Sat, Sep-30-2017, 02:02:10 AM   #26
How do you code out the dead zone? If that is easy let's get someone to make a graded gauge face stick on for the cluster.
Old Sun, Oct-01-2017, 01:44:25 AM   #27
jayjaya29
Photographer
jayjaya29's Avatar
Thermostat and waterpump are fine. Expansion tank did not crack like I initially thought.
I pulled the head off and there are no visible issues with the head gasket, just looks old and crusty. I think with as many miles as my car has on it (170K) its just time for the HG to be done.
Old Sun, Oct-01-2017, 03:02:38 AM   #28
Hallatauer
Track Rat
Hallatauer's Avatar
Reputation: 0 Hallatauer is on a distinguished road
I was running hot like you were/are... added a Zionsville rad kit with a Spal fan plus the oil cooler setup. Made a dramatic difference. My coolant temp stays in the normal operating range, even on a hot 95-100F day at COTA. My oil temps before would hit 270F.. now run 220-230F.
If your running regular track/HPDE's something to consider adding.
Jump to top Hallatauer is offline   Reply With Quote
Old Sun, Oct-01-2017, 05:16:22 PM   #29
nholmes
Track Junky
nholmes's Avatar
It requires an old laptop with a serial port
a legit 20 pin interface with a serial port connector (http://openlabs.co/store/Tiny-ADS-In...-pin-connector)
Old version of INPA
NCS Expert + NCS Dummy
(Both here: http://www.bimmerforums.com/forum/sh...0#post29024210)
Discussing How high is too high with water temp on the track? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
