Old Mon, Oct-09-2017, 07:26:16 PM   #11
03.5_m3_dinans2
03.5_m3_dinans2's Avatar
Reputation: 0 03.5_m3_dinans2 is on a distinguished road
Default Re: SMG issue right after Vanos refresh (gears not changing)
Anyone? SMG gurus?
Jump to top 03.5_m3_dinans2 is offline   Reply With Quote
Old Tue, Oct-10-2017, 03:10:45 PM   #12
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default SMG issue right after Vanos refresh (gears not changing)
Just adding some info here which somewhat related to yours.
I have a similar issue (stuck in neutral and wonít engage into gear). But my fault codes are different.
Codes:
58(088) adaptation values
32(650) selection angle cannot be engaged
38(056) on period Hydraulic unit.
Iím in the process of changing out the gps and the compression spring. If it still fails, next up is the actuator.
Last year, I already changed the motor (burkhart) and accumulator. It drove fine for a year until now.
Smg can be pita but Iím at ~200k. Knock on wood.. what other smg parts can break???
Tischer aka GetBmwParts
Old Wed, Oct-11-2017, 01:40:57 AM   #13
95///M3
Reputation: 0 95///M3 is on a distinguished road
I have issues after trying to reset all adaptations and having it fail on gear 4. Result was a seized gearshift selector rod joint. Replaced that. Re did the adaptations. Working great ever since...
Jump to top 95///M3 is offline   Reply With Quote
Old Wed, Oct-11-2017, 06:20:15 AM   #14
daytonaviolet
OEM CSL Whoore
what were the fault codes?
Old Wed, Oct-11-2017, 03:13:27 PM   #15
03.5_m3_dinans2
You have a part number for what you replaced?
Old Wed, Oct-11-2017, 03:15:30 PM   #16
03.5_m3_dinans2
Codes:
Do you remember the codes when you changed the motor (burkhart) and accumulator?
Let me know how it does when you replace gps and compression springs.
Thanks!
Old Wed, Oct-11-2017, 03:44:22 PM   #17
daytonaviolet
OEM CSL Whoore
Thanks!
Here are the codes which led me to change the motor.
73 SMG: Load deactivation
38 SMG: ON period, hydraulic unit (OBDII:P1717)
35 SMG: Hydraulic pressure loss in system (OBDII: P1715)
smg stuck neutral gear vanos
Discussing SMG issue right after Vanos refresh (gears not changing) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
