Old Thu, Oct-12-2017, 07:06:04 PM   #781
Default Re: The Official E46 M3 Oil Analysis Results Thread
Originally Posted by zeta456 View Post
Blackstone said my Castrol 0/60 was down to a 50 grade after 5K miles.
It has always become a 50 weight almost immediately. This is not a bad thing.
Old Thu, Oct-12-2017, 07:25:50 PM   #782
rhythim
Career parts guy
Reputation: 0 rhythim is on a distinguished road
Originally Posted by WyattH View Post
Thanks, guys. Yes original bearings.
Nice. That's about how mine looked for my last analysis with ~70K on the replacement set (116K on the car). 3 copper/1 lead on a ~4800 mile OCI.
Jump to top rhythim is offline   Reply With Quote
Old Thu, Oct-12-2017, 08:24:07 PM   #783
Yep and a 40 weight not long after. Old TWS used to hold better, but it was made of better base stocks
/// 2004 SilberGrau M3 Coupe 6MT slicktop manual seats no nav______________________JOURNAL
-Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Euro Headers|sect 1 BMW Motorsport 4.10 Besian D/A pullies/fan delete WPC rod bearings
-TMS Camber & Subf plates RE Street Trans Mounts AKG poly SUB/DIFF SDW RTAB ZHP knob + UUC DSSR GroundControl S/A (Koni/Eibach 440/550) + tall RSMs
-OE CSL trunk APEX 75mm Studs Sportline 8S 18"x8.5/9.5" MPSS 245/275 ss brake/clutch lines
-Pioneer DEH-80PRS Eclipse PA5422 CDT HD-6 + WS-100i CDT EX-530 8" Kicker
Old Thu, Oct-12-2017, 08:25:14 PM   #784
Old versions actually held at 50 for pretty much the duration, as I remember.
... though I never ran it longer than 7000 miles, so can't really say.
Old Sat, Oct-21-2017, 05:56:04 AM   #785
jxnguyen
Reputation: 0 jxnguyen is on a distinguished road
Just checking back in. Here are the rod bearings that had the extremely high levels of iron copper and lead. Still think there was a high possibility that there was an additive of some sort. Rod bearings 4 & 5 were the worse in my opinion. I also attached the oil analysis before the rod bearings were changed for reference.
Sidenote. What is everyone using for image hosting??
Jump to top jxnguyen is offline   Reply With Quote
Old Sat, Oct-21-2017, 03:32:05 PM   #786
nasieg
nasieg's Avatar
I assume that 2500 miles is probably not enough miles for this oil analysis? But what if said 2500 mills included 3 HPDE's?
My dilemma is that I only drive the car about 5000 miles per year and also change the oil very often, at least every other track event. At the same time, I'd like to get the oil test done. So maybe this is my chance, because I had 3 track events in a 6 week span and never got around changing the oil in between.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is online now   Reply With Quote
Old Sat, Oct-21-2017, 04:09:24 PM   #787
Why so many oil changes?
If you think it's too soon for analysis to be meaningful, because nothing significant has occurred... why are you changing the oil?
Old Sat, Oct-21-2017, 04:18:30 PM   #788
nasieg
nasieg's Avatar
The first owner was obsessive about the oil change and I can't argue the results, although that is not to say that it would be worse with less changes, as you have proven with your engine looking as clean also.
Never the less, oil gets dirty and breaks down at high temps, so it is just peace of mind.
I really don't expect to find anything wrong with the engine at this mileage, but still curious.
My Journal
Old Sat, Oct-21-2017, 04:42:13 PM   #789
So if it's stable (which is a big assumption granted), would M1 5w-50 be the "ideal" year round oil for the s54?
Old Mon, Oct-23-2017, 03:00:34 AM   #790
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
You need to replace your rod bearings now.
Thx Ian. I think I could've lasted another...1,000 miles...LOL. (In reference to my numbers at post #657 = http://www.m3forum.net/m3forum/showp...&postcount=657) Pulled them off at 132K. The worst was the rod side for #2 and then #1.
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Discussing The Official E46 M3 Oil Analysis Results Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
