Old Sun, Feb-26-2012, 06:29:16 PM   #41
Jmsimmons1
Reputation: 0 Jmsimmons1 is on a distinguished road
Default Re: DIY: Cheap Rear Quarter Panel Window Stripping Replacement
Originally Posted by mcclaskz View Post
Any feedback on how long the generic weather strip will last?
As of month 8, it looks exactly as good as the day that I put it on. No warping, cracking, fading. Looks factory.
Jump to top Jmsimmons1 is offline   Reply With Quote
Old Sun, Feb-26-2012, 06:30:10 PM   #42
///M_Achilles
"Visor down for business"
///M_Achilles's Avatar
Reputation: 0 ///M_Achilles is on a distinguished road
Thanks for the DIY; mine seals are rotted horribly! Will be doing this soon.
2005 Carbon Black Metallic ///M3
My Journal
Jump to top ///M_Achilles is offline   Reply With Quote
Old Mon, Feb-27-2012, 02:22:57 AM   #43
skeelo34
Registered Abuser
Reputation: 0 skeelo34 is on a distinguished road
I did mine about 2-3 yrs ago in the same way as described here. Still looks as good as they day I did it.
Jump to top skeelo34 is offline   Reply With Quote
Old Wed, Mar-07-2012, 11:07:15 PM   #44
Patrick///M3
Reputation: 0 Patrick///M3 is on a distinguished road
My effort turned out like ****. I can't see how kinking at the elbow can be avoided. I am extremely frustrated at the disconnect between my effort and OP's. FTS.
Jump to top Patrick///M3 is offline   Reply With Quote
Old Wed, Mar-07-2012, 11:15:46 PM   #45
JANDREF321
JANDREF321's Avatar
Reputation: 0 JANDREF321 is on a distinguished road
I used this to do my windows a few weeks back...Also had the kinking issue but played with it till it looked decent and now I can't tell with the window closed. That stripping is pretty soft though and playing with it for too long can make it look worn.
Jump to top JANDREF321 is offline   Reply With Quote
Old Thu, Mar-08-2012, 12:42:49 AM   #46
Patrick///M3
Ya, it got better after I adjusted it while trim was installed on the car. It looks better now.
Old Thu, Mar-08-2012, 04:46:48 AM   #47
Patrick///M3
OP, thanks for the DIY. I sorted it out and it looks pretty good.
Old Fri, Jun-08-2012, 03:25:02 PM   #48
iPhone
Reputation: 0 iPhone is on a distinguished road
Is it one 8' weather stripping per side (i.e. if we are replacing driver and pass. side, we need 16' of weather stripping)?
Jump to top iPhone is offline   Reply With Quote
Old Tue, Jun-12-2012, 05:51:45 PM   #49
Jmsimmons1
No.
8 FEET of weather stripping should be more than enough to do both windows with probably a little bit left over. The only reason I can think that would require another pack is if you somehow mess up one side and can not reuse your materials.
Old Mon, Jul-09-2012, 12:58:48 AM   #50
coldone4
coldone4's Avatar
Reputation: 0 coldone4 is on a distinguished road
Originally Posted by kokgo20 View Post
Anyone got any idea on that elbow fix?
I used a short length of clear plastic tubing that fit inside the seal.I only used it in the kink.
2004 BMW ///M3 Coupe SMG TiAG/CP CRT/Borla Muffler/Turner Underdrive Pulleys/Ebay Headers/Rial Daytonas
Jump to top coldone4 is offline   Reply With Quote
Discussing DIY: Cheap Rear Quarter Panel Window Stripping Replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
