Old Tue, Sep-27-2011, 09:37:37 AM   #31
Jmsimmons1
Reputation: 0 Jmsimmons1 is on a distinguished road
Default Re: DIY: Cheap Rear Quarter Panel Window Stripping Replacement
Originally Posted by kokgo20 View Post
Anyone got any idea on that elbow fix?
Hello kokogo,
My elbow did not kink and is smooth along the curve. However, it was necessary to properly aligned the spline of the weather seal within the track and if done correctly, it will look perfect BEFORE you put the rail back on the car. Without pictures from you, I can only guess though. Did you use a wide flat head screw driver to wedge the spline into the track?
It is also possible that the weather seal is "bunched up" at the elbow and could be stretched out a bit towards the nearest end on the rail. Careful though. The weather seal can rip if pulled to hard.
I hope that helps.
Jump to top Jmsimmons1 is offline   Reply With Quote
Old Tue, Sep-27-2011, 02:48:55 PM   #32
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
I took out a small loan and replaced the entire piece on both sides.
SOLD2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
Current ride: 2015 F32 435i xDrive with PPK
Jump to top GRKM3 is offline   Reply With Quote
Old Tue, Sep-27-2011, 05:14:39 PM   #33
kokgo20
kokgo20's Avatar
Originally Posted by Jmsimmons1 View Post
Hello kokogo,
I hope that helps.
Yeah i used a screw driver to wedge the spline into the track, i will take it off again within 2 weeks to replace the bottom strip, i was board last weekend so decided to get once side done just to see how hard it is, it was easy since i took the rear vent window out also, but i will try to align the spline farther away from the elbow to try to avoid that kink.
Will post some pics while I'm doing the other side.
Do u have a close pic of that elbow before install? just to kinda see how it suppose to look.
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - BMW MS 4.10 - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom A/F & boost gauge - Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast -
Jump to top kokgo20 is online now   Reply With Quote
Old Tue, Sep-27-2011, 05:58:16 PM   #34
mpegripper
mpegripper's Avatar
United Kingdom
how long did this take you?
Old Tue, Sep-27-2011, 07:26:16 PM   #35
kokgo20
kokgo20's Avatar
About an hour
Build thread
Old Wed, Oct-26-2011, 03:15:48 AM   #36
m3lulude
Reputation: 0 m3lulude is on a distinguished road
Thanks for the diy. I'm going crazy with the wind whistling in the rear.
Jump to top m3lulude is offline   Reply With Quote
Old Sun, Jan-22-2012, 04:22:17 PM   #37
mcclaskz
Purple in Sector 1
mcclaskz's Avatar
Reputation: 0 mcclaskz is on a distinguished road
Great DIY! I just completed the job and it was straight forward thanks to the pictures. I would advise getting all the adhesive tape residue off the lower trim piece. That part took the longest, but the end result was great. Any feedback on how long the generic weather strip will last? I used the same piece for a job on the back of my truck as well. Hopefully it will hold up. Also the lower outer trim piece that I ordered from ECS is now black hard plastic instead of rubber coated. It looks better and should hold up longer.
Jump to top mcclaskz is offline   Reply With Quote
Old Thu, Feb-16-2012, 12:00:46 PM   #38
//AM3RIC
//AM3RIC's Avatar
Reputation: 0 //AM3RIC is on a distinguished road
I really need to get this done, my driver side seal is torn wide open.
I made an attempt this morning, although I couldn't get the main trim piece out of the way to get to the screws.
It says to just pull down... Its just friction...
Well I pulled down, hard! Thing wouldn't come off and I'm a pretty strong guy.
Is there some type of technique or tool I should be using for this?
So far it's just been frustrating!
Jump to top //AM3RIC is offline   Reply With Quote
Old Thu, Feb-16-2012, 12:02:34 PM   #39
//AM3RIC
//AM3RIC's Avatar
Yes! That whistle on the freeway is awful!
Old Sun, Feb-26-2012, 07:26:57 PM   #40
Jmsimmons1
America23, could you please take a picture of the trim piece that you are having a hard time moving down and post it?
Discussing DIY: Cheap Rear Quarter Panel Window Stripping Replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
