Old Thu, Jul-21-2011, 02:53:49 PM   #11
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
Default Re: DIY: Cheap Rear Quarter Panel Window Stripping Replacement
Well done. Mine is starting to crack too.
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Thu, Jul-21-2011, 05:00:14 PM   #12
mpegripper
mpegripper's Avatar
United Kingdom
the picture with the red backing tape confuses me a little. when you are wedging the weather stripping into the FSF i would assume you put the side of the weather stripping with the backing tape on it towards the top of the FSF (where you wouldn't see the red tape cuz its inside). i am obviously missing something there, is there a step i'm skipping over?
also when you say remove the backing tape up to the point where you wedged in the weather stripping, i assume this means from the back of the FSF to the corner and not the corner to where the door meets, right?
Old Thu, Jul-21-2011, 05:28:55 PM   #13
Jmsimmons1
Reputation: 0 Jmsimmons1 is on a distinguished road
That picture was an attempt to show where to cut the weather stripping while explaining that the red strip was the backing on the weather stripping adhesive. The horrible quality of the picture made it difficult to see what the red strip actually was.
When you push the spine of the weather stripping down into the FSF track near the elbow, you will not be able to see the red backing. This will then give you the natural alignment you need to place the weather stripping down the FSF. It will also keep the stripping from kinking up around the elbow bend. Once you are into the process, you will see what I am talking about.
Correct. You will start removing the backing tape on the weatherstripping at the same location of the picture you previously questioned. As you pull off the backing down towards the elbow, you will not be able to get to the backing that is down in the spine, or at least not easily. Simply pull the backing until it snaps off. You will not have to worry about the backing or adhesion down in the track because the stripping is tightly wedged in there.
I honestly can't see there being an issue with this, but again...we are kind of pioneering the process at this point.
Jump to top Jmsimmons1 is offline   Reply With Quote
Old Thu, Jul-21-2011, 05:56:10 PM   #14
mpegripper
mpegripper's Avatar
United Kingdom
thanks man, i'll definitely try this out
Old Thu, Jul-21-2011, 09:32:45 PM   #15
mpegripper
mpegripper's Avatar
United Kingdom
fyi, amazon sell the rubber as well for all of us lazy people:
http://www.amazon.com/Metro-Moulded-...1283957&sr=8-1
Old Thu, Jul-21-2011, 09:37:09 PM   #16
Nervous
Reputation: 0 Nervous is on a distinguished road
Hey, thanks! It is even cheaper than in autocrazone, no tax either! Since I have Prime, no shipping charges as well.
Jump to top Nervous is offline   Reply With Quote
Old Thu, Jul-21-2011, 09:40:19 PM   #17
Nervous
Does anybody know which weatherstripping will fit for the lower rear window trim?
Old Thu, Jul-21-2011, 09:43:36 PM   #18
mpegripper
mpegripper's Avatar
United Kingdom
amazon prime has changed my life
Old Thu, Jul-21-2011, 09:43:58 PM   #19
opey
opey's Avatar
Reputation: 0 opey is on a distinguished road
Originally Posted by mpower22 View Post
Subscribed. This looks great. Have you given it the hose test yet?
hose test for what? this trim does not seal water out of the car. the actual seal is on the inside of the window
04 IR/IR 6spd
sold =(
Jump to top opey is offline   Reply With Quote
Old Fri, Jul-22-2011, 04:26:23 AM   #20
mojito
mojito's Avatar
Reputation: 0 mojito is on a distinguished road
Very nice write up! I need to do this soon. Thanks.
Jump to top mojito is offline   Reply With Quote
Discussing DIY: Cheap Rear Quarter Panel Window Stripping Replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
