Old Thu, Oct-12-2017, 02:09:22 AM   #1591
paulclaude
paulclaude's Avatar
Reputation: 0 paulclaude is on a distinguished road
Scotland
Default Re: Official Dyno Thread
Originally Posted by digger View Post
Euro cars are more like 250-260whp. Pretty much all European dynos are bhp estimates idk why but they do. Sometimes you see rwhp sometimes coastdown losses. Paul could show the same graph but rwhp next time he's there as means for comparison. Dyno dynamics just adds like fixed ~20% for "shoot_6" which is not the most scientific method lol
Trying not to turn the thread into a UK vs. US dyno figure debate, but Dynojet dyno's also apply a correction factor, hence the over inflated 'whp' figures. I believe the non-corrected raw 'whp' figure from a Dyno Dynamics are similar to that of a Mustang Dyno. FWIW my last run was 322 'WHP' non-corrected.
The large deltas you guys end up with I think all come down to starting with the catted headers and conservative US tune. Throw a set of Euro Headers on and a tune and you are in the 300HP area, which isn't too far away from my stock figure. And then, there's your higher ambient temps vs. UK to throw into the mix. Either way, you can't directly compare dyno figures, so like I always say, it's the delta that matters.
2005 E46 M3 Track - DIY Tuned - SSV2/BW 3.5" Single Exit - Schrick 288/280 - AEM Infinity - Karbonius CSL Intake - Nitron NTR R3 - Turner ARBs - Poly Bushed - Apex ARC-8 Square Setup - Alcon 365/345mm F&R BBK - Corbeau Buckets - Sabelt Harnesses - SD Half Cage - 6MT Conv. w/CAE Ultra Shifter - Seibon CSL Carbon Boot - GSR Carbon Wings
Jump to top paulclaude is online now   Reply With Quote
Old Thu, Oct-12-2017, 05:48:12 AM   #1592
digger
I'm just pointing out mis informed posts from others not aware of the apples vs oranges they are talking about. I've seen dyno dynamics ( properly setup) vs dyno jet within the same day and on a 250 to 275 hp engine the difference was just under 5%. It appears as the power level goes up the difference become much more apparent.
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Thu, Oct-12-2017, 06:47:25 AM   #1593
paulclaude
paulclaude's Avatar
Scotland
When talking dyno figures, it's a bunch of mixed fruit. Even dyno's of the same type/manufacturer can read differently, so again it's hard to compare. That's why the delta between runs is really the only accurate measurement you can base things on.
We should be discussing how to improve/lift the curve, rather than comparison of the absolute number - would be far more constructive
Old Thu, Oct-12-2017, 08:48:08 AM   #1594
HassanEido
HassanEido's Avatar
Lebanon
This times a million
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
364.1 whp 287.8 wtq
Old Thu, Oct-12-2017, 08:24:18 PM   #1595
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Quoted because this concept can't be repeated enough.
IG: DrM3anM3
Mods: Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, .
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Old Thu, Oct-12-2017, 09:09:46 PM   #1596
Turb02
Turb02's Avatar
2003
Stage 2 gen3 AA SC (upgraded from 81 to 91 blower, not retuned)w/m kit and 70mm pulley
Recent MX:
fresh oil, air filter, coolant system, idlers and tensioner pulleys, belts.
Last valve adjustment and plug change was 15 months ago (~13000 miles)
Some reason Im only getting ~8.5PSI
Temp was 93, humidity was above 60%
75% smoothing
Active Autowerke Stage 2.5-AA Headers-Supersprint-Meisterschaft-Vorsteiner-Brembo-AC Schnitzer-BBS-CSL
6MT swapped-RTD shifter-Amber Gang
Jump to top Turb02 is online now   Reply With Quote
Old Fri, Oct-13-2017, 07:15:32 AM   #1597
digger
i dont disagree one bit, but the vast majority of people are looking at the final numbers in an absolute sense let alone area under the curve lol
1996 e36 M3 Evo
Old Fri, Oct-13-2017, 09:57:20 PM   #1598
Dr M3an M3
Dr M3an M3's Avatar
In that case, the vast majority of people would be wrong.
Looking at absolute numbers just seems like a fools errand. That being said, it seems like most people DO fall under that category. Everyone seems focused on the "My car has XXXhp" game as if it is a dick measuring contest. To me, this just seems to allude to the fact that those same people don't really understand the purpose of a dyno and how it is actually used. People seem to think it's like a weight scale, regardless of who's scale you are on or the 'conditions' 200lbs is 200lbs, right!? The reality is, with this analogy, everyone's scale reads a pound differently. One scale says 200lbs, another says 250lbs, and another says 180lbs. What matters is the change (delta) between runs, while keeping conditions to be as exact as possible between runs, not the absolute numbers which are all but meaningless unless you are on a manufacturer's engine dyno (which is almost never the case).
Gaining 20 pounds is gaining 20 pounds, regardless if one scale reads 200 to 220, 180-200, or 250-280. The final number doesn't really matter given the variance between dynos and all the ways one can manipulate those numbers to read however high one likes. What matters is the change being consistent. There is almost nothing absolute about the 'absolute numbers' by themselves.
IG: DrM3anM3
Old Fri, Oct-13-2017, 10:58:09 PM   #1599
digger
yeah thats why i point out things that may not be obvious to others with respect to different dynos and what is being presented and how this compares to other things. it is all relevant to a dyno thread.
1996 e36 M3 Evo
Old Fri, Oct-13-2017, 11:11:40 PM   #1600
Dr M3an M3
Dr M3an M3's Avatar
Absolutely.
IG: DrM3anM3
Discussing Official Dyno Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
