Old Wed, Oct-11-2017, 01:51:21 AM   #21
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default Re: Fix a sagging glove box door.
Originally Posted by Dino V View Post
does anyone else also have a loose center push button that opens glove box door? Mine falls off (doesn't stay secure on). I was going to order a new glovebox to fix sag but when I get some time I will check and see if tabs are broken on vent piece section first.
The button is broken where the spring goes in, easy to repair, did that on my M3 5 years ago, quite common problem. Done in 5 minutes
23 Push button SCHWARZ from 09/1993 51168170671 $2.53
23 Push button GRAU from 09/1993 51168170672 $2.53
23 Push button BEIGE from 09/1993 51168170673 $2.53
24 Compression spring from 09/1993 51168168865 $0.48
http://www.realoem.com/bmw/enUS/show...diagId=51_3080
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Wed, Oct-11-2017, 12:51:15 PM   #22
Poorhouse
Reputation: 0 Poorhouse is on a distinguished road
Originally Posted by SamGrant951 View Post
^ correct. Its about $85, just replaced mine.
Part #?
97 M3/4/5 - Sold
91 318iC
Jump to top Poorhouse is offline   Reply With Quote
Old Wed, Oct-11-2017, 02:30:27 PM   #23
SamGrant951
SamGrant951's Avatar
Reputation: 0 SamGrant951 is on a distinguished road
64228183040
86 951 - VEMS
95 M3 LTW - S54 http://www.bmwmregistry.com/detail.php?id=15735
17 GTI
Sold: 97 M3/4/6 Byzanz, 99 M Coupe, 02 M Coupe
Jump to top SamGrant951 is offline   Reply With Quote
Old Wed, Oct-11-2017, 03:25:57 PM   #24
Poorhouse
97 M3/4/5 - Sold
91 318iC
Old Fri, Oct-13-2017, 04:15:35 PM   #25
Dino V
Reputation: 0 Dino V is on a distinguished road
Thank you, much appreciated.
Jump to top Dino V is offline   Reply With Quote
Old Mon, Dec-04-2017, 09:03:39 PM   #26
Haywood
Reputation: 0 Haywood is on a distinguished road
Do you have a part number or link? Thanks.
Jump to top Haywood is offline   Reply With Quote
Old Mon, Dec-04-2017, 09:14:58 PM   #27
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by Poorhouse View Post
Part #?
64228183040
Posted a few posts up.
Old Mon, Dec-04-2017, 09:19:41 PM   #28
Haywood
Thanks, man.
Old Thu, Dec-14-2017, 01:44:17 PM   #29
Haywood
Guys,
Unfortunately, I ordered the part #64228183040 and it doesn't fit in my current glove box housing. The locking mechanism is different and it will not fit on the bottom. Anyone else have this issue?
Old Thu, Dec-14-2017, 05:05:40 PM   #30
Haywood.
What are we looking at? The sliding lock box in your left image is very early E36 (till 1993). The part number you ordered is not for that glovebox. If that’s what you received ordering that part number take it back to BMW, they messed up.
This is pn: 64228183040
If your car came with the sliding lock style, someone incorrectly equipped your car. You will also need the correct carrier for the vent section you ordered. I encourage you to put the correct glovebox in your 97.
glove box problem (nope, its not sagging) Vespoli E36 M3 (1992-1999) 1 Mon, Oct-13-2008 01:04:34 AM
Glove Box Hybrid Fix Isis M E36 M3 (1992-1999) 5 Mon, Apr-21-2008 12:32:44 PM
QUick E36 Saggy Glove Box Fix Doc_SoCal E36 M3 (1992-1999) 11 Tue, Jul-11-2006 03:49:01 PM
Sagging Muffler Fix... what worked best for you?? badgtho E36 M3 (1992-1999) 0 Sun, Jan-08-2006 03:54:06 PM
Fixing spllting glove box door VTRick01 E36 M3 (1992-1999) 19 Wed, Nov-17-2004 09:56:43 PM
Discussing Fix a sagging glove box door. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
