View Poll Results: Winter wheels
OEM 19" with winter tires (Current Wheels) and buy another summer wheels ? 0 0%
OEM E46 18" (Squared) 4 44.44%
OEM E9X 18" Wheels (Squared, Better fit) 1 11.11%
Apex 18" SM-10 0 0%
Apex 18" FL-5 1 11.11%
Other options ? 3 33.33%
Voters: 9. You may not vote on this poll
Old Tue, Oct-10-2017, 11:12:44 PM   #11
silvergray545
silvergray545's Avatar
Reputation: 0 silvergray545 is on a distinguished road
Default Re: Help needed for choosing winter wheels
Originally Posted by bullet0770 View Post
yup stock brakes and staying stock. which 17's?
Apex makes 17s. I'm sure you can even find something used over in the E36 crowd.
2004 BMW M3 6MT - TiAg/Gray
B&B TriFlow Section 3 | AP V2 headers | TMS Power Pulleys | aFe Drop In Dry Filter | Macht Schnell Intake Elbow | TTFS Tune | CSF Radiator & Oil Cooler | AST 4200 Coilovers | Ground Control Race Camber Plates & RSMs | TMS Rear Camber Arms | Hotchkis Front Sway Bar | Stoptech ST40 Front & Rear BBK | UUC EVO3 SSK with DSSR | ZHP Knob | Orion V4 | Matte Black Kidney/Side Grills | 35% Tint | Apex 75mm Wheel Studs | H&R Trak+ 10mm Spacers | 19" VMR CSL Reps | 245/275 Continental ExtremeContact DW
Track Stuff: Apex ARC-8s 18x10 ET25 | 275/35/18 Nitto NT01s | Schroth Quick Fits | PFC 08s
2000 BMW M Roadster 5MT - TiAg/Black
TCK D/A | Lightwerkz Projector Headlights | LeatherZ Interior Bits | BMW Performance Knob | OEM Square 17x9 Roadstars
2016 BMW M3 ZCP 6MT - AW/SO
Color Matched Front Reflectors | Lightweight Front Lip | M Performance Rear Spoiler | Black 666Ms
Instagram
E46 M3 Build Journal
Jump to top silvergray545 is offline   Reply With Quote
Old Wed, Oct-11-2017, 07:04:01 PM   #12
Washburn
Reputation: 0 Washburn is on a distinguished road
Those are some nice wheels for winters :P
Heh...I had them as leftovers from when I sold my E46 Touring. I didn't know about the 17's fitting, but these are sitting in the garage waiting to be used.
Jump to top Washburn is offline   Reply With Quote
Old Thu, Oct-12-2017, 02:36:57 AM   #13
Mach_3
Mach_3's Avatar
Reputation: 0 Mach_3 is on a distinguished road
As others have said, with snow tires narrower is better. Also, more sidewall is better, so I'd cross 19s off the list. Benefit of a square setup is tire rotation. This could add up over time -- good winter tires like Blizzaks are expensive. Benefit of going with OEM staggered setup is you may already own the wheels, and if not you can find a secondhand set cheap, plus the wheels will be more tucked in (less stuff down the side of the car, as Bimmerchop mentioned). If aesthetics matter, darker colors will hide the dirt and brake dust better.
I decided to buy two sets of Bimmerworld TA16s (gloss black) in 18x9.5 ET35, with studs and 12.5mm spacers in the rear. The winter set has Blizzak LM001s in 255/40-18. The width isn't ideal for winter, but I wanted two matched sets in case BW stops producing them and I bust a wheel. Plus, they are pretty sharp and I love 'em so far. This will be my first full winter with that setup, so I can't comment on how they perform, but my expectations for the Blizzaks are high based on past experience in other vehicles.
'06 M3 ZCP 6MT | Jet Black/Cinnamon | Dinan | UUC | Mishimoto | lots of little stuff
Jump to top Mach_3 is offline   Reply With Quote
Old Thu, Oct-12-2017, 02:47:45 AM   #14
Mach_3
Mach_3's Avatar
Originally Posted by Washburn View Post
I will be using 18x8 BBS RSK's for mine. 245-40-18 square. (Correct diameter)
If I were going with a winter only setup, this would be my choice.
Old Thu, Oct-12-2017, 03:16:56 AM   #15
ethan
Reputation: 0 ethan is on a distinguished road
I currently run square OE 18s with Michelin PA4s and it's glorious. Downside is chains don't fit, so if you live in a place where they're legally mandated in the winter (getting up to Alta or whatever) then you could opt for 225s on 17" wheels. I have a set of style 157s (8J ET34) from an E90 for that purpose, though I'm trying to get rid of them. They clear the stock brakes just fine, but the rear fenders look ridiculous even with spacers. With the sidewall height on a 225 17", you'll want to make sure you opt for something on the stiffer side (not WS80s e.g.).
Jump to top ethan is offline   Reply With Quote
Old Thu, Oct-12-2017, 03:24:44 AM   #16
L0ADED
L0ADED's Avatar
Can't go wrong with stock 18's and snow tires. Cheap, durable, stock offsets and widths, and classic E46 M3 look.
Discussing Help needed for choosing winter wheels in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
