Old Sun, Dec-09-2018, 05:11:20 AM   #11
Jaredomin
Jaredomin's Avatar
Reputation: 0 Jaredomin is on a distinguished road
Default Re: Front Ball Joints Failed
Originally Posted by bimmerfan08 View Post
I asked the same question years ago. Because the arms are aluminum they can't be repressed. Replacement ball joints don't exist. This was direct from Lemforder.
Beat me to it.
Pressing them can warp the aluminum due to it being so soft iirc
Jump to top Jaredomin is online now   Reply With Quote
Old Sun, Dec-09-2018, 02:14:44 PM   #12
BubbaTree
BubbaTree
Reputation: 0 BubbaTree is on a distinguished road
In reviewing my original comment, I didn't clearly describe my problem. I don't have any steering/suspension problems with the ball joint. The problem is a torn rubber grease boot, which seems to be leaking the grease. Maybe a better question is whether I can source a replacement grease boot. Both front wheels seem to be very solid, with no shake or vibration, so I'm reluctant to spend the money to replace both wishbones due to a grease leak. Anyone ever perform this repair, or know of a source for such a part?
Thanks, guys.
Jump to top BubbaTree is offline   Reply With Quote
Old Sun, Dec-09-2018, 06:18:18 PM   #13
KlausH79
Reputation: 0 KlausH79 is on a distinguished road
Hey
Replacement FCA Ball joints are only available for Merle HD FCA’s.
https://www.fcpeuro.com/products/bmw...31121126253hmy
https://www.fcpeuro.com/products/bmw...-31126758510my
But buy from FCP and you get new ones next time they need replacing as per their “Guaranteed for life” policy...
Jump to top KlausH79 is offline   Reply With Quote
Old Sun, Dec-09-2018, 06:22:02 PM   #14
Thanks, guys.
Doubt that you can just buy the boot. I’d try and find a boot from an old control arm. See if you can get it off intact.
You can try pulling the boot off, degreasing it and then use silicone to glue it back together.
You’re likely going to have to buy a new control arm. Probably not worth trying to repair what you have.
Old Sun, Dec-09-2018, 06:58:15 PM   #15
Originally Posted by KlausH79 View Post
Hey
Those won't work on the M3
Old Sun, Dec-09-2018, 07:26:00 PM   #16
Hey
Note that the M3 isn't on that list...
Discussing Front Ball Joints Failed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
