Old Sun, Jan-14-2018, 02:17:35 AM   #21
Jasoncor
Grumpy Young Man
Reputation: 0 Jasoncor has a spectacular aura about
Default Re: Oil change before or after car sits for awhile?
I do it before and drive it a little and let it cycle through the engine. I think that makes the most sense.
Jump to top Jasoncor is online now   Reply With Quote
Old Sun, Jan-14-2018, 04:15:44 AM   #22
RedM3/4
Engines sit for years and with some pentrating oil in the cylinders and a hand crank to ensure nothing is bound up restart fine, so corrosion isn't an issue.
Also, even the best synthetics will "wax up" if they sit for a couple days or more under freezing. So I'd always do after if in anywhere near cold weather.
For before, I'd probably put in a good quality, 0w-30 dino or synthethic oil to:
1. get the dirt flushed out
2. get me the best possible flow for the first start after sitting; THIS is where wear occurs, at startup. The colder it is, the worse the wear.
All your going to do is get it hot and flush it anyway when you return.
ADS
Old Sun, Jan-14-2018, 05:18:39 PM   #23
Joshe46
Joshe46's Avatar
While were on this topic, for those changing after, I’ve been wondering should we do the oil change immediately? Before ever starting the car or should we drive it first? I know hot oil changes are better. But what’s everyone’s opinion on this?
Jump to top Joshe46 is offline   Reply With Quote
Old Sun, Jan-14-2018, 05:30:50 PM   #24
lmtfi
lmtfi's Avatar
You're over-thinking this.
Your oil hasn't suddenly become poisonous over the winter.
Old Sun, Jan-14-2018, 05:51:01 PM   #25
Joshe46
Joshe46's Avatar
Lol alright! But I don’t mean that as if the oil is no good, but in terms of minimizing wear on the initial start up after 5 months. A fresh oil change would at least splash some oil up top.
Old Sun, Jan-14-2018, 08:50:03 PM   #26
grannyknot
Reputation: 0 grannyknot is on a distinguished road
Which is where the pre oiler comes in, it doesn't just splash little bit around, it primes every moving part in the engine so it is fully coated in lubricant
Jump to top grannyknot is offline   Reply With Quote
Old Sun, Jan-14-2018, 10:20:58 PM   #27
Joshe46
Joshe46's Avatar
Never knew that!
Old Sun, Jan-14-2018, 10:56:21 PM   #28
elgallo3354
Reputation: 0 elgallo3354 is on a distinguished road
I would definitely change it before you go. I used to race in the summer and old oil that sits in the engine will release acids and other chemicals that can eat away or pit on the close tolerance parts.
Jump to top elgallo3354 is online now   Reply With Quote
Old Mon, Jan-15-2018, 12:10:11 AM   #29
voyager006
Spartans Never Retreat
voyager006's Avatar
Reputation: 0 voyager006 is on a distinguished road
A few years back my logic was to change after winter to remove any water condensate after sitting
Currently my logic is to change before (Michigan winter in my case) to remove oil with combustion products and maybe reduce corrosion anywhere the oil sit in pocket
One might deduce that there is no right or wrong…. Pick your logic….
Forged 6061-T6 RAC 63 rims wrapped w/ PSS (285/35/18, 255/35/18) Sweet!
Bilstein B6-OEM
Winter arrived; BBBks work w/ stock 18 rims/PSAS w/ 17.5mm spacers (spacers just for winter events)
Jump to top voyager006 is offline   Reply With Quote
Old Mon, Jan-15-2018, 12:16:54 AM   #30
nogoodname
Taking a dump
nogoodname's Avatar
Reputation: 0 nogoodname is on a distinguished road
Yeah warm oil drains better but chances are with the car sitting for some length of time. Most of the oil is down in the pan. I change mine just before the first start. At least there will be some oil at the top and in the filter area this way.
But I just do both. Before and after lol
Tiag/Imola 6MT
Status Gruppe | Coby Wheel | Apex | CPI | KW | Mishimoto | TTFS
Jump to top nogoodname is offline   Reply With Quote
Discussing Oil change before or after car sits for awhile? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
