Old Thu, Jan-11-2018, 08:55:58 PM   #11
grannyknot
Reputation: 0 grannyknot is on a distinguished road
Default Re: Oil change before or after car sits for awhile?
Drain it before you deploy, put a note taped to the steering wheel that says "NO OIL, DO NOT START"
When you get back crack open your fresh oil and fill, Fresh oil sitting in an oil pan for six months isn't helping the engine or your wallet.
Jump to top grannyknot is offline   Reply With Quote
Old Thu, Jan-11-2018, 10:21:24 PM   #12
Toxic0n
Wouldn't sitting for months with no oil introduce corrosion internally to areas that are normally lubricated?
Ground Control, Mason Engineering, HRE, ACS, Rogue Engineering
Jump to top Toxic0n is offline   Reply With Quote
Old Thu, Jan-11-2018, 10:46:38 PM   #13
2006E46M3fan
2006E46M3fan's Avatar
Here's a thread where I asked the same thing recently:
http://www.m3forum.net/m3forum/showthread.php?t=593426
Jump to top 2006E46M3fan is online now   Reply With Quote
Old Thu, Jan-11-2018, 11:46:41 PM   #14
erickrayos
True, if somehow there's moisture inside that will promote corrosion.
To me it really doesn't matter, both before and after have their points.
Before, since you wouldn't want any dirty oil settling down might as well store it with fresh oil like storing a gallon of oil in your garage.
after, if it's good enough to run this engine that goes to 8k+ rpm then it should be good enough to sit there.
Thing is you don't want the oil to be really really old.
I think fuel is more of an issue than the oil.
Jump to top erickrayos is online now   Reply With Quote
Old Fri, Jan-12-2018, 01:47:28 AM   #15
grannyknot
No, your 5-6 liters of oil (clean or dirty) are completely covered by the windage baffles that are cast into the oil pan, if the engine isn't running that oil just sits there in the pan waiting for the engine to start, it won't make any difference to any of the engine parts whether that oil pan is empty of full. If moisture gets inside the engine having a pool of oil in the bottom of the pan still isn't going to help.
Old Fri, Jan-12-2018, 03:46:19 AM   #16
mrgizmo04
mrgizmo04's Avatar
Precisely! You can put gold into your oil pan, but if the car just sits, and you don't start it, there won't be any oil (or gold in this case) circulating through the head or any other components, since the oil pump is mechanically driven via a chain off the crank sprocket.
Same discussion in the thread 2006E46M3fan posted.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jan-12-2018, 04:09:40 PM   #17
killa_e46
killa_e46's Avatar
Reputation: 0 killa_e46 is on a distinguished road
I would do an oil change after. If you are worried about the fuel, throw in some fuel stabilizer according to the amount of time you are gone and then also let the car sit on a tender. Then you are golden
Jump to top killa_e46 is offline   Reply With Quote
Old Sat, Jan-13-2018, 03:20:03 AM   #18
chatcher
Reputation: 0 chatcher is on a distinguished road
After has worked well for me, been winter storing my cars for 2 decades.
current rides:
2009 Zr1
2012 Navigator
2008 4.8i E70 X5
2008 F450 Dually
2013 135i
2005 E83 X3 3.0
2003 rc51
1999 F350 Dually
Running out Garage space!!
Jump to top chatcher is offline   Reply With Quote
Old Sat, Jan-13-2018, 03:36:55 AM   #19
twentyseven
@itsmejonnyv
twentyseven's Avatar
It's either man-made or it's been sitting in the Earth for billions of years.. it's not perishable guys. And you don't have a vortex of dirt swirling around in there either - that is what a filter is for. Letting it sit for a few months won't hurt anything, including the oil's feelings.
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is online now   Reply With Quote
Old Sun, Jan-14-2018, 02:43:41 AM   #20
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
No need to replace oil donít go bad based on time.
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is online now   Reply With Quote
Discussing Oil change before or after car sits for awhile? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
