Old Wed, Jan-10-2018, 04:26:29 PM   #1
wolffbimmer
Reputation: 0 wolffbimmer is on a distinguished road
Default Axle or Differential Play?
I have a 2002 M3 and I have some nice clunks sometimes from the rear end when shifting. The car has had the subframe reinforced so that should be ruled out. Underneath the car I was looking around and the right side (passenger) rear axle has a lot of slop and I believe it's causing my clunk. I can also recreate the clunk by going on and off the throttle abruptly.
See video below
Jump to top wolffbimmer is offline   Reply With Quote
Old Wed, Jan-10-2018, 04:51:18 PM   #2
rovert604
rovert604's Avatar
Default Re: Axle or Differential Play?
Most likely it could be your one front diff bolt not being torqued down enough. You may also want to check your two rear diff bolts too.
I had my car Vincebar and skinzíed recently and after driving bolts may come loose so you need to retorque just like you would do wheel bolts.
I was able to recreate diff knock on abrupt throttle. Now my car is silent!
--Trevor in 604--
Vancouver, BC, Canada
Old Wed, Jan-10-2018, 05:00:39 PM   #3
wolffbimmer
I've checked the differential bolts on the rear and the front one as I read those are common "come loose" bolts. They are good. It's not the differential that is moving as a whole in the video. It's just the rear axle/CV/output shaft of the differential. I have new axles to replace the old ones but I'm concerned it may be something worn inside the actual differential. I plan on popping out the entire output shafts and doing the inner/outer seal and slip ring.
Old Wed, Jan-10-2018, 05:02:49 PM   #4
PITT M3 RR
PA
PITT M3 RR's Avatar
Probably a combination of everything under there. M variable lsd wear, CV wear, bushing wear etc. these cars can be quiet, but often are found to have this wear. Hold the hub and see if you have radial wear in the CV too.
My Imola 02 clunked horribly, replaced the diff with a different unit and fixed 70% of it I’d say. My 04 is clunk free. Also had an 02 very that was clunk free.
S54 E36 BUILD
Old Wed, Jan-10-2018, 05:28:58 PM   #5
fattycharged
can't even
fattycharged's Avatar
Zimbabwe
normal movement imo, if that front bolt is not fully torqued down it will clunk abnormally
Topo Chico
Old Wed, Jan-10-2018, 06:02:49 PM   #6
wolffbimmer
It's crazy to think that play is normal but I've seen that now several places for just the right side. Is it possible to change the side bearings on the differential while it is on the car still? Maybe that is a bit worn too.
Old Wed, Jan-10-2018, 07:41:28 PM   #7
fattycharged
can't even
Zimbabwe
Not really sure what would be considered a positive maintenance move unless itís leaking fluid. I had a severe clunk that I was sure must be the diff, turned out my front bolt was just slightly loose and the clunk was brutal. Tightened that back down and all is good
Topo Chico
Old Thu, Jan-11-2018, 04:05:01 PM   #8
wolffbimmer
I decided to go with the masses here and I ordered two updated/revised rear differential bolts and washers and one front differential bolt from BMW. Will be in Friday so I'll install that evening and report back. I'm getting a lot of different torque specs on the forums and various places. The rear bolts I'm seeing at 60/61 ft/lbs plus a 90 degree turn, then I saw on this forum 15 ft/lbs and a 90 degree turn. The front bolt I'm seeing 148 ft/lbs 128/ft lbs etc. Does anyone have a definitive answer?
Old Thu, Jan-11-2018, 04:14:22 PM   #9
PITT M3 RR
PA
PITT M3 RR's Avatar
http://sawashie.free.fr/M3/TorqueSpe...SPECS%20LR.pdf
S54 E36 BUILD
Old Thu, Jan-11-2018, 04:25:13 PM   #10
wolffbimmer
Thanks a million. Saving that to my phone. There's a big thread on here for the DIY on these bolts and he had 61 ft/lbs. That's a big difference. Hope people didn't break bolts.
Discussing Axle or Differential Play? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
