Old Fri, Jan-12-2018, 10:09:36 PM   #431
e36 323ti
e36 323ti's Avatar
Reputation: 0 e36 323ti is on a distinguished road
Norway
Default Re: Brembo Caliper/AP Racing Style Disc Kit -- Group-Buy Interest Thread
Originally Posted by CLAWHAMM3R View Post
Oh I meant for this kit. They're using a the e9x M rotor which is 360.
Using pad width as an estimate for center of the rotor diameter, per p0lar's equations. I used his calculations minus all the pressure stuff for a simple calculator and I get 66.29% front bias for stock, pretty close to your model.
They said the kit uses an EV0X pad (131mmx75mm), but I forgot I'm still using the stock pad for the caliper (132x76).
So...width or height?
Height.
First post says "All in all, this kit will offer exactly the same front piston area as on the AP RACING e46 KIT and the exact same disc diameter..." and "... an AP Racing disc can be purchased separately and mounted when our discs wear off", hence I use 356mm (as for the AP kit).
The surfcae of the pad material of the AP-pad for the AP kit has a height of 54mm (D54) and is covering most of the AP rotor surface height. If the AP rotor can be used as a replacement, I assumed the Brembo pad had close to the same height. Assuming your data is correct, I do not see how the AP rotor can be used as a replacement if the pad surface in the Brembo kit has a height of 75mm. Assuming their info is correct, the surfcae of the Brembo pad can't be 75mm high...?
Jump to top e36 323ti is offline   Reply With Quote
Old Fri, Jan-12-2018, 11:26:55 PM   #432
C///M
Originally Posted by e36 323ti View Post
Height.
That first post is super outdated. You guys need to wait, they haven't even provided a final parts list.
Jump to top C///M is online now   Reply With Quote
Old Sat, Jan-13-2018, 11:19:02 AM   #433
Bubblegunz
Reputation: 0 Bubblegunz is on a distinguished road
Bulgaria
EVO X pad hight of the full pad 75mm, including the metal bracket and extentions top and bottom. The actual ferodo in the middle (shortest distance) is 52mm so it is not an issue to fit on a 54mm disc. We scraped the idea of that disc anyway, but as I said - some mistakes have been made.
Also with the 49% of the ZCP rotor, is wrong, as the pad WIDTH was taken in the calculation (I believe you posted it). You need the pad height, when calculating the radius from the center of the disc to the center of the piston, not the width, and that is still assuming the pad highest point is the disc's highest point. Furthermore you need the hieght of the FERODO (actual pad) not the height of the pad+metal plate behind it, as it extends above the height of the disc to the caliper pins.
More info will be availiable soon, I am just pointing some things out.
- Antony
Jump to top Bubblegunz is online now   Reply With Quote
Old Sat, Jan-13-2018, 07:41:09 PM   #434
VaruzhM3
Reputation: 0 VaruzhM3 is on a distinguished road
Armenia
If this is still going on, I’m interested
2005 BMW M3 Silver Gray/Black 6MT
1999 BMW M3 Alpine White/Dove Gray 5MT
2007 Toyota FJ Cruiser Black/Black 6MT
Jump to top VaruzhM3 is online now   Reply With Quote
Old Sat, Jan-13-2018, 08:28:11 PM   #435
BennyK
Reputation: 0 BennyK is on a distinguished road
Interested too!
Jump to top BennyK is offline   Reply With Quote
Old Tue, Jan-16-2018, 04:40:37 PM   #436
BlackBand
Reputation: 0 BlackBand is on a distinguished road
Hong Kong
I am interested. I have Brembo GT 4 piston kit already. would this kit using the same brackets? Can I just order the caliper only?
Jump to top BlackBand is offline   Reply With Quote
Old Sun, Jan-21-2018, 11:29:19 PM   #437
whips333
whips333's Avatar
Just checking in for an update?
Old Mon, Jan-22-2018, 12:18:54 AM   #438
T-Rex
Reputation: 0 T-Rex is on a distinguished road
+1
Bit the bullet and installed new rotors today - super excited for this (but not looking forward to installing)
Jump to top T-Rex is offline   Reply With Quote
Old Mon, Jan-22-2018, 01:07:35 AM   #439
mopsauce
Reputation: 0 mopsauce is on a distinguished road
1. SQ13
2. whips333
3. 2006E46M3fan
4. Kyle90
5. Drlph25
6. Marioec
7. henryc
8. Yanksfan e46
9. Sashman123
10. Jchan112
11. Khan Art
12. Jared212
13. castaway
14.rkymtnrider
15.speedblind_az
16. Samsonite79
17. dothraki
18. MPowerZ32
29. E30toF30
20. chranotik
21.Cmda17
22. Lux1200
23. rramseyr
24. Tbonem3
25. Boostkid
26. repoman89
27. Bimmerboi19
28. Jersey3
29. D-O
30. cwlo
31. wheelhead
32. cozmo kraemer
33. T-Rex
34. smbz2789
35. TheM
36. 94runner
37. Silvertail
38. ATB88
39. Mercedesc63
40. jfh342
41. TheDoogan
42. RedM3/4
43. rtong
44. jlrichar
45. Loi-Spec
46. phunguy8624
47. Bgoodman
48. SHRMN8TR
49. Mveneros
50. Sweet Jones
51. Cncmastr
52. MasterC17
53. Mopsauce
Jump to top mopsauce is offline   Reply With Quote
Old Mon, Jan-22-2018, 04:47:55 PM   #440
Bubblegunz
Bulgaria
Hi Guys,
Small update here. The kit and brackets are ready. I just ordered the braided brake lines from Goodrich, and they should be here in 10 work days (arround 2 weeks). After that all will be photographed therally - placed on the car and the GB will be opened! Havn't been too active here lately - we are just developing a lot of things, so I hope you understand.
- Antony
Discussing Brembo Caliper/AP Racing Style Disc Kit -- Group-Buy Interest Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
