Old Thu, Dec-20-2012, 03:53:05 PM   #31
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Default Re: KhanArt's Jet Black///Cinnamon 6spd E46 M3 looong term journal
Originally Posted by Kal_el View Post
The spacers helped. Looks great!
Thanks, I agree. Really set the OEM wheels off
Originally Posted by checkmate1 View Post
20mm spacers up front??? Any steering wheel vibrations?
No not at all, I had more of an issue with the rears rubbing. I had my rear fenders rolled but still have some slight rubbing from time to time on the passenger rear.
I've seen a few guys on here do 20mm up front on the oem 19's with no issue so I went with it.
Build///Journal
IG: @Khan_Art_
Old Sun, Jan-27-2013, 03:25:12 AM   #32
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Originally Posted by KhanArt View Post
Update (11/10/2012)
I got a baseline dyno today. I am very happy with my numbers 288.1 whp. Minor mods and a custom tune is where I will begin.
I apologize, on that dyno run on 11/10/12 when the car made 288.1whp it was NOT completely stock. It had a tune. I had no way of knowing. The number wasn't outrageous so we just thought it was a strong car. We discovered that the car had a tune today when testing the car on the dyno and the numbers were too high to be stock.
Also from that dyno run let me add my car had old gas which was probably sitting there for some time. I do not daily drive the car and that was the first nice day we had in a long time and I took it out for the meet. If you have been following the thread about Dave (Dafoe), he had a similar issue with bad gas and bad spark plugs.
Also let me add from that dyno run we did not stabilize air temps, so it wasn't completely accurate. I had a dyno session today with accurate results. I will post up soon.
Build///Journal
IG: @Khan_Art_
Old Sun, Jan-27-2013, 03:51:12 AM   #33
Busabos77
Sexinator
Busabos77's Avatar
Reputation: 0 Busabos77 is on a distinguished road
Either way man, great numbers still... Not bad!
Jump to top Busabos77 is offline   Reply With Quote
Old Sun, Jan-27-2013, 04:01:27 AM   #34
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Thanks man
Build///Journal
IG: @Khan_Art_
Old Sun, Jan-27-2013, 04:05:11 AM   #35
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Update (1/26/13) CPI RTX Rasp Terminator (section 1)
http://www.custom-performance.net/pr...rt/pc/home.asp
CPI RTX Thread:
http://m3forum.net/m3forum/showthread.php?t=432648
Let me begin by thanking Jack from CPI (Custom Performance Innovations) and Frank Smith from Tuning Tech Frank Smith for allowing me to work with them on this product.
The main purpose of this part was to eliminate the rasp on a stock M3 and I can say it has achieved that! The rasp is completely gone and sounds clean now. I will post better videos of the sound hopefully tomorrow. I also want to add that this piece is slightly angled up at the resonators to help with clearance.
During the before dyno runs on my car today it was putting down great numbers..over 300whp so Frank couldn't believe it and said he had to take my car 2 bays down to another dyno to make sure. My car at the second dyno again made over 300whp. He said there is now way this car can be stock so we checked the DME and as he suspected the car had a tune. He believes it is a Active Autowerks tune from the maps.
All runs were 4th gear pulls.
Conditions:
Before dyno at the other shop:
Before dyno graph from the other dyno, the 287 was a misread:
Before dyno graph from Frank's dyno:
After CPI RTX installed dyno:
After CPI RTX Installed dyno graph:
Before and after on the same graph:
This is the icing on the cake! Not only did it remove the rasp it showed 2-4 whp and ft/lb torque gains throughout the mid range power band. 306.9whp before, 307.9whp after. 250ft/lb torque before, 253ft/lb torque after. They only change made to the car from the before and after dyno runs was the CPI RTX.
OEM Section 1:
CPI RTX:
OEM Section 1 removed:
Now here are some final pics of it installed. Notice how the piece angles up when it nears the resonators. It is tucked in there pretty good for lowered cars like mine.
Here is a video of the start up and take off:
I am very happy with the product.
Build///Journal
IG: @Khan_Art_
Old Sun, Jan-27-2013, 04:22:46 AM   #36
vongeiss
JerseyShoreM3
Reputation: 0 vongeiss is on a distinguished road
Wow those are impressive numbers, I can't wait to get down to Frank in the next month or so!
2002 ///M3 Carbon Black - current
2002 ///M3 Steel grey / Imola Red - RIP
2001 325i Steel Grey - sold and missed
Instagram: @VONGEISS
Jump to top vongeiss is offline   Reply With Quote
Old Sun, Jan-27-2013, 09:54:46 PM   #37
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Frank's the man! I learn so much every time from him.
Build///Journal
IG: @Khan_Art_
Old Thu, Jan-31-2013, 07:03:22 PM   #38
GaM3r
ESS VT2-550
GaM3r's Avatar
Reputation: 0 GaM3r is on a distinguished road
I'm liking the build journal so far!
CPI is a local shop to people in NOVA right? I'm wondering if the Rasp eliminator will work with an FI setup.
The dealer should have charged you more for having a tuned M3!
The underside of your M looks immaculate. Your car is super clean, grats.
///M
*ESS VT2-550 --Euro Headers/CPI RTX Section 1 --TC Kline True Match --Vorschlag Cambers --VB3's --HPF Stage 1 Clutch
Jump to top GaM3r is offline   Reply With Quote
Old Thu, Jan-31-2013, 07:18:05 PM   #39
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Thanks Brandon!
Yes CPI is located in Stafford, VA but I believe they only make and sell their own products as well as sell VRM, SS, AP, and other products. They do not do installs. They are a sponser here. Jack the founder is a great guy. I drove down to his home and met him in person and had a good chat. His M3 is very nice as well.
CPI RTX Thread:
This new RTX I have will work on FI ONLY if you run cat less. They do not have a catted version and it can't be made since with cats they can't incorporate the H pipe.
Yes now that I think of it I got a great deal!! The dealer did not know what they had and that it was tuned. This car has been one positive surprise after another. Hope it stays that way. Yes this car is crazy clean... if you think the underside looks clean then you should have seen it before, that was after driving to Frank's shop in Bmore with all the crap on the road.
Looking forward to the dyno day. I hope I can pull out a few more hp after changing spark plugs
Build///Journal
IG: @Khan_Art_
Old Sun, Feb-03-2013, 04:31:04 AM   #40
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Update (2/2/2013) Spark plugs, Cleaned MAF sensor, and replaced wipers.
After seeing what a difference spark plugs did to Dave's (Dafoes) dyno numbers. I decided that would be the next maintenance item on my list. Member Drew (boomersooner523) provided me a link to great deal on some NGK Iridiums.
Before vs. after
Pieces cleaned ready to go back on
Old spark plugs
Spark plug DIY threads and video:
http://www.m3forum.net/m3forum/showt...&highlight=DIY
http://forum.e46fanatics.com/showthread.php?t=902734
My wife picked me up some wipers from Costco I like this new style of wiper. I was going to get the Bosch Icon but I will try these out.
Gave my MAF sensor a quick spray down. 4-10 hp to the wheels, lol!
Thread for MAF Sensor cleaning DIY:
http://www.m3forum.net/m3forum/showp...6&postcount=22
I went to check my battery since I never inspected it and did not know what I had back there. Pleasantly surprised again it was changed with a Optima Red Top battery. A little weight saving over stock.
Build///Journal
IG: @Khan_Art_
Discussing KhanArt's Jet Black///Cinnamon 6spd E46 M3 looong term journal in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
