Old Sat, Oct-16-2010, 12:41:01 AM   #1
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Default Differential Seal Leak (with pictures)
Well, as soon as I thought everything was running great on my car, I find a leak in my differential seal. I keep a close eye on everything so I know this JUST started. I smelled it a little when getting out of my car at work this morning. I smelled it again when I got home and threw my car up on the lift. This is what I found. It is leaking pretty good as you can see from the spray and the drips.
I have done some research already on this, please post any experience you have with replacing these. I learned not to press the seals in too far from doing some research. Any help would be appreciated before I start this, but I think it will be pretty straight forward. I have had the diff. out of my car in the past for the 4.10 upgrade.
TIA,
Mr. Wolfe
1994 Porsche 911 Factory Widebody
Old Sat, Oct-16-2010, 12:45:32 AM   #2
nis350
nis350's Avatar
Reputation: 0 nis350 is on a distinguished road
From all the posts I've read, it is usually a common slow leak and some just ignored it. This appears to be a very bad leak since you mentioned this is new.
Did you hit something?
Jump to top nis350 is offline   Reply With Quote
Old Sat, Oct-16-2010, 12:49:55 AM   #3
Rendezvous
Rendezvous's Avatar
Reputation: 0 Rendezvous is on a distinguished road
Germany
Mine leaks a tinny bit also. Yours looks pretty bad though.
Jump to top Rendezvous is offline   Reply With Quote
Old Sat, Oct-16-2010, 12:54:09 AM   #4
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
I definitely did not hit anything. I am positive of this. I have not had the car on the rack for a month or so, but I wash the car every week so I know it wasn't leaking last Friday. The inside barrel of the driver side wheel and the exhaust tips have diff fluid on them. It's like the seal "blew" or something. IDK.
Mr. Wolfe
Old Sat, Oct-16-2010, 12:55:58 AM   #5
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
This is especially annoying because you can usually eat off the bottom of my car.
Mr. Wolfe
Old Sat, Oct-16-2010, 01:02:40 AM   #6
Fuerza
strength
Reputation: 0 Fuerza is on a distinguished road
Mr. Wolfe
I thought the diff in our cars was sealed with RTV?
Jump to top Fuerza is offline   Reply With Quote
Old Sat, Oct-16-2010, 01:17:55 AM   #7
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
There is an actual seal that is pressed into where the axle spline enters the diff.
Mr. Wolfe
Old Sat, Oct-16-2010, 01:22:08 AM   #8
quaixe
ATL M Rider
quaixe's Avatar
Reputation: 0 quaixe is on a distinguished road
is it the pinon seal ?
Jump to top quaixe is offline   Reply With Quote
Old Sat, Oct-16-2010, 02:29:15 AM   #9
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
Damn that looks bad! Are you going to pull it?
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Sat, Oct-16-2010, 02:36:57 AM   #10
tjpatte
Reputation: 0 tjpatte is a jewel in the rough
That is pretty bad. Might want to make sure the housing vent isn't plugged. If it gets plugged the housing will pressurize while driving and force fluid past the seals.
Tom
2004 Mystic Blue M3
Jump to top tjpatte is offline   Reply With Quote
differential, leak, pictures, seal
Discussing Differential Seal Leak (with pictures) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
