Old Tue, May-03-2011, 05:49:05 AM   #31
I M Legend
Default Re: Replaced Differential seals but ow they leak worse
Problem solved...seal was indeed in too far. Thanks!
Old Tue, Aug-26-2014, 03:05:41 PM   #32
Hrvat
Reputation: 0 Hrvat is on a distinguished road
Nitro, you are the life saver! After massive leak I had due to seal being pushed in too far, I ordered new one and tapped it in per your instructions, flushed diff with liquid gold fluid ($$$) and all good now
Jump to top Hrvat is offline   Reply With Quote
Old Tue, Aug-26-2014, 11:09:49 PM   #33
Mlust
Reputation: 0 Mlust is on a distinguished road
nice! will have to store this info for later.
Jump to top Mlust is offline   Reply With Quote
Old Wed, Aug-27-2014, 12:12:47 AM   #34
duracellttu
Wow..this info would have been worth its weight in gold a few weeks ago. I replaced my seals during my subframe reinforcement and had them leak too, but I didn't realize it until it was too late. I lost all the oil I'm my diff and had it seize on me. Been a nightmare ever since. Ended up having to get a rebuilt diff. Silverlining is that I upgraded to 3.91 gear ratio.
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY!
Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates
Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan
AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
differential, leak, replaced, seals, worse
DIY: Differential output shaft seals JeST Faults, Fixes and DIY 41 Mon, Sep-11-2017 10:43:24 PM
Differential seals leaking? Pictures nitro3421 E46 M3 (2001-2006) 48 Thu, Sep-10-2015 07:08:25 PM
Had a cat replaced..rasp is WORSE! m3 hammerdown E46 M3 (2001-2006) 3 Tue, Nov-18-2008 04:57:48 AM
Even Worse. Diff Leak **Pic** _XeRo_ E36 M3 (1992-1999) 35 Sat, Mar-01-2008 12:11:57 PM
Leaking differential seals Terrapin E46 M3 (2001-2006) 6 Sun, Nov-11-2007 12:01:35 AM
Discussing Replaced Differential seals but ow they leak worse in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
