Old Tue, Mar-31-2009, 08:19:32 AM   #11
darkcrash21
///Mike
darkcrash21's Avatar
Reputation: 0 darkcrash21 is on a distinguished road
South Korea
subscribed... i'm going to have to do this to mine as well
2002 ///M3 Carbon Black / CF interior
VF-Engineering Stage 2 ● Tial Q BOV ● Okada Projects ● AEM Water/Meth ● Stoptech BBK ST60/ST40 ● HPF Stage 1 Feramic Clutch ● HPF/Walbro Fuel Pump ● Mason Engineering F/R Strut Bar and Clutch Pedal ● Ground Control SuperStreet Double Adj Coilovers w/ Hyperco 600F/700R ● Treehouse FCAB ● UUC Rear Lower Control Arms ● Eibach F/R Adj Sway Bars ● Agency Power Headers ● CPI section 1 w/ 400cell cats ● RE X-pipe with EVC ● RE El Diablo Ti ● Platte Forme AG Rear Subframe Reinforcement ● lots and lots of other crap...
Jump to top darkcrash21 is offline   Reply With Quote
Old Tue, Mar-31-2009, 12:24:46 PM   #12
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
The passenger side axle shaft has an allowed radial play of a mm. And I could have sworn the longer axle shaft is on the passenger side, because of this, and the shorter axle shaft goes in the driverside...
Here's a post of mine from a while ago straight from TIS (bmw na):
Originally Posted by BMW NA
Further drivetrain checks reveal that the right side rear axle output flange appears to have "excessive" or more play (approximately 0.5mm to almost 1mm) when compared to the left side output flange. The radial play on the right side rear axle flange is a normal design characteristic of the new M differential lock style rear axle used on E46 M3 models.
Therefore an M3 differential should not be replaced due to a difference in play (when comparing left to right side differential output flange play) or "excessive" flange play since this will not eliminate a drivetrain rattle or knocking noise.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Tue, Mar-31-2009, 01:08:46 PM   #13
dsm918
dsm918's Avatar
Reputation: 0 dsm918 is on a distinguished road
Offtopic...Like the TT in your sig. I still miss mine
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
00 GSXR 600 (Track Star)
90 Nissan 300ZXTT
92 Eclipse GSX - 11.841 @ 117.11
Jump to top dsm918 is offline   Reply With Quote
Old Tue, Mar-31-2009, 09:24:55 PM   #14
vespam5
vespam5's Avatar
Reputation: 0 vespam5 is on a distinguished road
No luck yet guys.
Parting out my 2002 m3 PY/Black Leather
SubFrame ReEnforced with Turner plates!
Evosport Software/Denso Iridiums/Redline Drivetrain fluids/Motul 600 brake+clutch fluid/Rogue RTABs/UUC SS clutch line/CDV delete/Rogue Trans mounts/OEM retrofitted NAV/OEM strut bar/
Jump to top vespam5 is offline   Reply With Quote
Old Tue, Mar-31-2009, 10:00:27 PM   #15
vespam5
vespam5's Avatar
I'm going to do it one more time and not push the seals in all the way. I think that the grooves created by the original seals are the problem and I need to move the seal outward about 1mm or so.
I'll check in with a result boys n girls.
Does BMW happen to make ring spacers or special seal for this situation?
Old Tue, Mar-31-2009, 10:48:52 PM   #16
JeST
Old Skool
JeST's Avatar
China
After reading your post (#10) did you by any chance accidentally mix up the axle shafts?
Big Single + Meth
Old Tue, Mar-31-2009, 11:45:09 PM   #17
vespam5
vespam5's Avatar
No, that's impossible.
Old Wed, Apr-01-2009, 05:21:14 AM   #18
nitro3421
nitro3421's Avatar
Reputation: 0 nitro3421 is on a distinguished road
I did the seals last weekend and had the SAME problem. I put the first seal in (victor reinz), put everything back together, and it leaked WORSE. If you look at the spline, theres only a certain length of it that will touch the seal. Therefore, if you push the seals in too far, the spline wont make contact with the seal itself and will leak. You're on the right track - dont push them in nearly as far. I ended up pushing my seal in about 1/3 of the total distance I could push it in if I kept pounding. I'll try to post some pictures tomorrow showing exactly how far it needs to be pushed in. I pushed it in so the outside face of the seal was set in about 1/4" from the entrance of the "shaft" your pushing it into.
I redid them pushing it in the distance described above and it's dry as a bone 500 miles later. Long story short, dont push the seal in too far because it wont create the required contact with the spline shaft.
Jump to top nitro3421 is offline   Reply With Quote
Old Wed, Apr-01-2009, 12:50:03 PM   #19
nitro3421
nitro3421's Avatar
Here's a picture of my original seal below. Notice the depth it's set in. There is a gap between the inside face of the seal and the end of the shaft your pounding it into - it's not pressed all the way into the shaft, rather it only sits about a 1/4" in the shaft. The distance between the two white lines in the picture show this 1/4" (in fact i'd say its actually a bit less than 1/4"). Hope this helps!
Old Wed, Apr-01-2009, 01:13:50 PM   #20
nitro3421
nitro3421's Avatar
Here's another picture showing where the seal makes contact with the spline shaft:
differential, leak, replaced, seals, worse
DIY: Differential output shaft seals JeST Faults, Fixes and DIY 41 Mon, Sep-11-2017 09:43:24 PM
Differential seals leaking? Pictures nitro3421 E46 M3 (2001-2006) 48 Thu, Sep-10-2015 06:08:25 PM
Had a cat replaced..rasp is WORSE! m3 hammerdown E46 M3 (2001-2006) 3 Tue, Nov-18-2008 03:57:48 AM
Even Worse. Diff Leak **Pic** _XeRo_ E36 M3 (1992-1999) 35 Sat, Mar-01-2008 11:11:57 AM
Leaking differential seals Terrapin E46 M3 (2001-2006) 6 Sat, Nov-10-2007 11:01:35 PM
Discussing Replaced Differential seals but ow they leak worse in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
