Old Thu, Feb-23-2017, 10:06:30 PM   #221
mpower22
CPV O-Ring Guy
mpower22's Avatar
Default Re: DIY: Differential fluid change
Originally Posted by Maxima SE View Post
can anyone describe the noise u hear after the fluid change? is it like a clicking noise when u drive straight?
Negative. Should not be any clicking at all (maybe the clicking is referring to another issue other than the diff such as the endlinks).
The sound is like a low deep groan, sometimes vibrating the chassis slowly, but it's not repetitive and you will hear it, like someone moaning in a deep tone or something.
///M3 - Dream Car: Acquired 11/18/02
15-Year Forum Member
2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/[CSL] Exhaust
Old Fri, Feb-24-2017, 12:28:43 AM   #222
Maxima SE
445 FTW
Maxima SE's Avatar
Reputation: 0 Maxima SE is on a distinguished road
hmmm weird. i gotta jack mine back up and find out whats going on then. after flushing the fluid from royal purple to OE i have this weird loud clicking gear on gear noise. constant tick tick tick that gets faster and louder as you speed up. i thought that was what was expected but it didnt go away so i asked...
2005 6MT Phoenix Yellow///M3
Jump to top Maxima SE is offline   Reply With Quote
Old Fri, Feb-24-2017, 02:59:15 AM   #223
admranger
Registered troublemaker
Did you inadvertently move the heat shield by the driveshaft and it's touching one of the bolts or something?
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Sat, Mar-11-2017, 10:39:40 PM   #224
Maxima SE
445 FTW
Maxima SE's Avatar
had a chance to jack it up and inspect the heat shields. that wasn't it. i even pulled it down to clear the driveshaft and still the noise can easily be heard when driving. i turned the rear wheels with the car on jackstands and couldnt hear it. will probably jack it up and put it in drive and have a friend see where it is coming from. literally the only thing i did was change the diff fluid and go from 12 mm spacers to 10mm in the rear and this noise started....
change, diff, differential, diy, fluid
Differential Fluid Replacement DIY needed M302_IMOLA E46 M3 (2001-2006) 57 Tue, Mar-24-2009 07:27:55 PM
Good DIY link for replacing Differential Fluid? rockne E46 M3 (2001-2006) 0 Thu, Nov-29-2007 10:17:50 PM
Differential fluid change DIY. MIA?? bagzman E46 M3 (2001-2006) 8 Tue, Nov-13-2007 02:50:03 PM
DIY Oil change, Air Filter Change, Spark Plug and Brake Fluid NooK E36 M3 (1992-1999) 6 Tue, Jun-05-2007 03:53:05 AM
Differential fluid change questions ryanK Faults, Fixes and DIY 0 Thu, Feb-09-2006 01:31:34 PM
Discussing DIY: Differential fluid change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
