Old Fri, Dec-29-2017, 11:44:35 PM   #1
KevinLarson
Reputation: 0 KevinLarson is on a distinguished road
Default Dying Seats
Has anyone recently dyed their seats?
I was planning on rewrapping them this winter, but am getting more and more into the idea of dying them, as mine are in pretty good condition with no rips or anything and seams in good shape. Just want them to look better.
Does anyone have a list of products or a recent DIY? All the ones I can find are old and the products don't exist anymore. Also whats your experience with it?
Jump to top KevinLarson is offline   Reply With Quote
Old Sat, Dec-30-2017, 12:42:11 AM   #2
Texaz3
Default Re: Dying Seats
http://www.m3forum.net/m3forum/showthread.php?t=593871
Pages 3 have some info. I'm not really an expert, just remember seeing the above recently.
https://www.leatherworldtech.com/Lea...int-s/1960.htm
Old Sat, Dec-30-2017, 08:17:23 AM   #3
bmwstephen
I recommend using furniture clinic products because they use urethane based products instead of latex or waterbase like most products on the market
Jump to top bmwstephen is offline   Reply With Quote
Old Tue, Jan-02-2018, 05:56:37 PM   #4
Mpower5266
Reputation: 0 Mpower5266 is on a distinguished road
I just used the stuff from leatherworldtech and they came out great. Not perfect but way better than before and they look great in the car. I just hope they hold up well.
Untitled by mpower5266, on Flickr
Jump to top Mpower5266 is offline   Reply With Quote
Old Sat, Jan-06-2018, 03:04:48 AM   #5
blau mit weiss
Reputation: 0 blau mit weiss is on a distinguished road
I have. I used Colourlock from the UK (though the bottle says it's from Germany.)
www.colourlock.com
They have a BMW Napa leather black that was an exact match for my 97 M3. Not sure what color you're looking for, but check them out, they have a fairly extensive color chart.
Jump to top blau mit weiss is offline   Reply With Quote
Old Sat, Jan-06-2018, 03:42:12 AM   #6
SQ13
Oh shit! I was thinking about having FibreNew do my driver seat, but I might have to give DIY refinishing a try. How would I go about repairing split leather? These are the seats. Doesn’t look like seats off a 99k mile car. Evtron’s car has nearly 80k more miles than mine, but his seats look much, much better.
Old Sat, Jan-06-2018, 03:12:29 PM   #7
Texaz3
You essentially put a patch under the leather split, then fix the crack with the leather filler, sand smooth, and re-coat with leather dye/sealer.
Old Thu, Jan-11-2018, 04:11:32 PM   #8
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
That is the type of damage where you really should replace the leather. Either have an upholsterer replace the damaged leather with some donor BMW nappa, or source a whole new bottom Vader cushion that is in better condition. Because you are looking to do a color refinishing, it doesn't really matter which color replacement leather you go with.
Leather refinishing is a lot like bodywork: the quality of the end result is determined by the quality of the substrate preparation. You shouldn't just weld a patch of steel on the backside of a body panel, and then slop gops of filler on top, if the body panel had a large rip or rust through areas in it. The same principle applies to your seat and you want to use a minimal amount of leather filler just as you want to use a minimal amount of body filler when doing body work.
Discussing Dying Seats in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
