Old Sat, Mar-28-2015, 11:36:47 AM   #1
humarahumara
Reputation: 0 humarahumara is on a distinguished road
Default Brake hose threads showing after installing new caliper??
Hey all,
Need some help here. Installed rebuilt drivers front caliper on my 95 m3. (Both calipers were replaced last year but drivers front seized on me last week.)When reattaching brake hose everything seems smooth except when it came to tighten down, there were still 2 lines of threads still showing as if the brake hose wasn't tight. It is tight and I don't want to overtightened. Is this normal? Didn't see any leaks when i went to bleed but i'm paranoid now.
what should i do? I'm concerned that stuff/water/crap may start to work into the exposed threads.
Jump to top humarahumara is offline   Reply With Quote
Old Sat, Mar-28-2015, 03:36:53 PM   #2
68coug
Reputation: 0 68coug is on a distinguished road
Default Re: Brake hose threads showing after installing new caliper??
Originally Posted by humarahumara View Post
Hey all,
I'm assuming you purchased remanufactured calipers rather than rebuilding the originals. The remanufacturers typically blast the outside to remove rust the put a rust prohibitor on (which does not work).
Those 2 processes typically leave the internal threads rough causing the brake hose not to seat all the way. It probably won't leak, don't overtighten.
Jump to top 68coug is offline   Reply With Quote
Old Sat, Mar-28-2015, 04:18:58 PM   #3
humarahumara
Yes they were remanufactured. I see. Will keep me eye on it. Anyone else have similar experience?
Old Sat, Mar-28-2015, 10:44:08 PM   #4
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
Don't be immediately concerned because the threaded fitting from the brake line to caliper isn't going to come loose if it's torqued properly. I've seen this same issue of the flange on a threaded fitting on the brake lines not making contact with the brake caliper. The brake line can last many thousands of miles, without the flange-head on the fitting contacting the brake caliper, without coming loose. This issue can also because of aftermarket brake hoses, like stainless-steel lines, which don't necessarily have the same length of threaded flange as a real OEM brake line.
The solution is to install a shim (washer) between the brake caliper and brake-line threaded flange to eliminate the possibility of the line rattling loose. About two threads on an M10x1.0 fitting is about two millimeters of thickness, and it's easy to find a washer of that thickness.
This is a parts-defect, though, so replace the brake caliper(s) (or brake lines if applicable) if you are really that concerned about the issue.
Old Sun, Mar-29-2015, 01:13:57 AM   #5
jayjaya29
Photographer
jayjaya29's Avatar
Perfectly normal. Carry on.
Old Mon, Mar-30-2015, 06:01:09 AM   #6
M3AN
321 fun...
M3AN's Avatar
New Zealand
...When reattaching brake hose everything seems smooth except when it came to tighten down, there were still 2 lines of threads still showing as if the brake hose wasn't tight.
This.
And not this.
/// E36 M3 Coupe / Estoril Blue / Lotus White
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein B6 / Eibach Pro+ / BBS RC / Goodyear F1 / Rally Road Bits / 3.62 CWP (TBI)
Jump to top M3AN is online now   Reply With Quote
Old Tue, Mar-31-2015, 01:01:17 AM   #7
Earthwormjlm
Imolarot M3
Perfectly normal. My OEM brake lines and calipers do this.
Old Wed, Apr-01-2015, 02:17:32 AM   #8
humarahumara
Much appreciated guys! Checked again this morning. No leaks, everything all good!
Discussing Brake hose threads showing after installing new caliper?? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
