Old Tue, Apr-14-2015, 02:56:29 AM   #1
likwidmonster
likwidmonster's Avatar
Reputation: 0 likwidmonster is on a distinguished road
Default Evap Leak
Hello,
I am getting a CEL for an evap leak and believe I found the source but want confirmation on my findings. I am also looking for advice on the repair.
See the photos below.
Thanks for the help guys!
Jump to top likwidmonster is offline   Reply With Quote
Old Tue, Apr-14-2015, 09:23:13 AM   #2
falciott
falciott's Avatar
Reputation: 0 falciott is on a distinguished road
Default Re: Evap Leak
A broken nipple on that tank will definitely throw an evap code, mine did . .but it wasn't the bottom nipple that had a crack, it was the top one . I didn't attempt to repair it ,although there are dyi s that show you how , but I doubted their reliability . I just ended up buying a new tank .
1997 Glaciersilber M3.
Clear lights, Corsa RSC36, DJ Auto with TFX retrofit, Blind spot monitoring system, Illuminated ZHP knob,Brushed aluminum look console and bits,Flat bottom MTechnic steering wheel, Becker Grand Prix with bluetooth, Motion sensor HD dash cam, BMW Homelink, Keyless entry, RE short shifter,CSL reps, Mason strutbar,Reverse sensors, Automatic rain sensing wipers, everything else? Stock!
Jump to top falciott is offline   Reply With Quote
Old Tue, Apr-14-2015, 04:00:32 PM   #3
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
Reputation: 0 Jrrrrrrr is on a distinguished road
That's the fuel evaporative liquid/vapor separator -it's not uncommon for one of the nipples to break and cause a leak code.
Luckily, this part is the same on all obd-2 e36s, so it's not hard to find. Jb weld, epoxy, or even plastic welding (polypropylene iirc) could all work depending on where the crack is. IE, if the crack is at the junction of the tank and nipple, you'd be better off replacing the whole tank.
Jump to top Jrrrrrrr is offline   Reply With Quote
Discussing Evap Leak in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
