Old Fri, Nov-08-2019, 04:00:44 AM   #11
castaway
¯`•...¸><((((º>`• .¸¸.•´¯`•.¸
castaway's Avatar
Reputation: 0 castaway is on a distinguished road
Poland
Default Re: Random Engine Knock When Sitting Still
Hi Evan,
Coils were all replaced after 1 failed about 3 years ago, so they're fairly new. Hope that helps.
I don't recall the car knocking at idle. Sometimes it would "hiccup" at idle, but it's done that forever and I considered it an M quirk.
2003 ///M3 6MT
Steel Gray / Imola
Jump to top castaway is offline   Reply With Quote
Old Fri, Nov-08-2019, 07:29:17 AM   #12
evanr614
Reputation: 0 evanr614 is on a distinguished road
Originally Posted by castaway View Post
Hi Evan,
Look at you still lurking! Haha when you say hiccup would say it felt like a small “thud”? Also no RPM fluctuation?
Originally Posted by Kurty View Post
I have the same problem occuring from time to time.
Knock is probably the word I would choose to describe it too. It would knock and you can feel the engine just skip a beat pretty much. Goes away with any throttle input.
I've changed pump, filter, fuel regulator, injectors, coils & sparks. Kinda gave up chasing it. Doesn't do it all the time either. I catch it from time to time.
“skip a beat” is probably the best way to describe it!
Jump to top evanr614 is offline   Reply With Quote
Old Fri, Nov-08-2019, 08:07:14 AM   #13
ATB88
Reputation: 0 ATB88 is on a distinguished road
I actually get this "soft thudding" with no RPM variation at idle too, but only on cold starts. I've always been curious if it's normal and what it is (misfire? knock?)
Jump to top ATB88 is offline   Reply With Quote
Old Fri, Nov-08-2019, 01:25:45 PM   #14
evanr614
Min will happen when completely warmed up
Old Sat, Nov-09-2019, 02:55:47 AM   #15
Kurty
Reputation: 0 Kurty is on a distinguished road
Yeah mine feels solid even at -22F cold starts.
Jump to top Kurty is offline   Reply With Quote
Old Sat, Nov-09-2019, 04:27:30 AM   #16
Aux water pump maybe?
Old Sat, Nov-09-2019, 12:27:22 PM   #17
evanr614
Wow, didn’t even know this was a thing until just now doing some searching. You think this part can make some noise if failing?
Old Sun, Nov-10-2019, 06:34:26 PM   #18
evanr614
After a couple drives today I noticed the knock/hiccup actually did kick the idle around a very small amount. Does this changed any of your guys’ opinions?
Old Sun, Nov-10-2019, 07:53:42 PM   #19
vivid02
vivid02's Avatar
Reputation: 0 vivid02 is on a distinguished road
I had an idle pulley that would make an occasional knocking sound every once in a while. At first it was very faint and at idle only. A month later it became more consistent but only at idle. I noticed it was coming from the very front of the engine and narrowed it down to the pulleys area.
At times I miss my Arrrrr...
Jump to top vivid02 is offline   Reply With Quote
Old Sun, Nov-10-2019, 07:55:07 PM   #20
evanr614
Could it be felt throughout the car?
Discussing Random Engine Knock When Sitting Still in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
