Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Cars for Sale/Wanted
Cars for Sale/Wanted Place to list your private cars for sale. ONLY BMW's.
Old Sun, May-26-2019, 08:06:22 PM   #1
E.Hands
Reputation: 0 E.Hands is on a distinguished road
Default S-54 Turbo M Coupe
- Car year, make and model=2001 BMW M Coupe
- Vin number=LK60038
- Mileage=103,000
- List of options/packages=All: Sunroof, In-dash CD, Rear CD Changer
- Length of ownership=Original owner
- Any maintenance records=Very extensive
- Car location= Youngsville, Louisiana
- Willing to ship?=Yes
- Asking price= $38,000
Please provide picture of the vehicle:
Original owner, 2001 M Coupe that has a Maximum PSI, Stage 2 turbo kit. Please see MaximumPSI.com for additional details. This kit retains the factory DME and can be serviced using factory diagnostic tools such as: INPA, DIS, OBD, etc. It also has dual tunes in the ECU, one for pump gas and one for race fuel.
In addition, the turbo was upgraded to the Precision Turbo, Gen2 PT6266 CEA DBB CHRA (Competition Engineered Aerodynamics with a Dual Ball Bearing, Center Hung Rotating Assembly). A Full custom built, TIG welded, 304 Stainless Steel, Vibrant Muffler exhaust from turbo to tail pipes. New motor mounts. A RaceLogic Traction Control system in addition to the original DSC.
As a preventative precaution prior to going with forced induction the following modifications were performed by The man, The myth Randy Forbes himself:
1) Connecting rod bearings were updated with dry film lubricated upgraded M3 bearings. (Originals saved for inspection)
2) Vanos exhaust 1st generation cam bolts upgraded with updated replacements.
3) All valves clearances checked/adjusted.
4) Oil pump pulley nut tack welded in place.
5) Randy Forbes trunk floor/differential mount upgrade w/Rogue dual ear differential cover, Ireland Engineering subframe bushings and adjustable toe/camber kit.
Other mods include:
UUC 1-piece, light weight stage 2 flywheel w/M5 pressure plate & M5 sprung hub organic clutch disc
UUC black transmission mounts with enforcers
UUC ultimate short shifter
TC Kline D/A coilovers, adjustable camber plates, 400/500 #/in., height adjustable springs, & HD shock mounts
T.C. Kline 700 Lbs/in rear barrel spring set
Eurosport power pulleys: alternator, power steering, water pump
Weldcraft Modified Roadstars 17x9, 17x11, Polished lips & power coated centers
Toyo Proxies R888 255/40/17 Fronts, 315/35/17 Rear
Drilled & Slotted rotors, Hawk ceramic pads, stainless steel brake lines
Quaife Automatic Torque Biasing Differential 3.73:1 with Amsol Oil
Clear front side marker lights
Leather Z Estoril Blue door & center armrests & Rear hatch leather insert
Custom thick foam padded, perforated leather wrapped steering wheel with M stitching
Strong Strut Aero Ducts
Motion Motor Sports aluminum under body panel
New M floor mats front & rear
Rogue Engineering clutch stop
Mason Engineering front strut brace
H&R wheel spacers
Doug Whalen Shift Machine shift knob, aluminum hood release lever & seat bushings w/ tilt mod
Modified (raised) & original chrome ringed M rearview mirrors (original has Ron Stygar alarm LED)
Clutch Delay Valve delete hoses & original hose
Grom Audio Bluetooth, hands free phone adapter, upgraded amp & speakers
10” & 12” powered Bazooka Bass tubes w/ dash mounted cross over & gain control
Valentine one radar detector upgraded with the latest software updates
Windows 7 Laptop computer w/ INPA software & hardware for BMW diagnostics
R5/FXC (II) Engine scan reset tool from Peake Research
Pro Clip cell phone mount
Spare set of original Roadstar Wheels w/ 235/40/17 & 255/40/17 Dunlop Star Specs
HIR headlights bulbs
ZHP shift knob
Jaffster V2 Tall Delrin Shift Knob
Original rod bearings, 3.15:1 posi-differential, intake manifold, headers with cats
Stage Two Turbo items:
Rally Road aluminum, steering column mounted gauge pod
Turbosmart eBoost2 electronic boost controller
AEM wideband O2 failsafe gauge w/boost display
Tial MVR waste gate & blow off diverter valves
Technique Tuning (NickG) dual tune turbo software
Walbro 485 fuel pump assembly & big ol’ injectors
Before and after turbo, dyno plot graphs
Power at the wheels, to the ground:
496 HP / 375 TQ on pump gas
703 HP / 509 TQ on race fuel
Serious driving enthusiast wanted: This is probably the most powerful stock DME S54 M Coupe in the world right now.
All receipts, documentation, original window sticker, keys, Blackstone Labs oil analysis reports, spare parts and extras. Many more mods, please ask…
-Ed Hands
6/02/19
Jump to top E.Hands is offline
Rate Seller View Rating
Old Sun, May-26-2019, 08:16:20 PM   #2
eson
eson's Avatar
Reputation: 0 eson is on a distinguished road
Default Re: S-54 Turbo M Coupe
PM'd.
Jump to top eson is offline   Reply With Quote
Old Tue, May-28-2019, 10:53:50 PM   #3
E.Hands
Originally Posted by eson View Post
PM'd.
I did not get your PM
Jump to top E.Hands is offline   Reply With Quote
Old Thu, May-30-2019, 02:21:57 PM   #4
wichonewichone
Reputation: 0 wichonewichone is on a distinguished road
Beautiful car, glws
Jump to top wichonewichone is offline   Reply With Quote
Old Sat, Jun-01-2019, 03:31:09 PM   #5
hyperboost
Imola Red M
hyperboost's Avatar
Reputation: 0 hyperboost is on a distinguished road
how much for your stage 2 turbo kit? are you willing to part out?
OEM+ E46 M3 IR/Black Cloth - light factory freak
ESS VT440|SS V1|Volk TE37|AS SSK|TCK S/A|Vorshalg Camber Plates|Brembo 8piston 380mm front 4piston 345mm rear|EAS AEs|PF RTAB|RE Tranny Mounts|RE FCAB & RSM|UUC front sway
E46 M3 TiAg/IR modded - sold
E92 M3 Melbourne Red 18" Volk TE37SL - Transported to China
E93 M3 AW/Black - sold
E39 540iA modded -sold
B6 A4 modded back to stock - totaled
W126 560SEC - Wintermobile - Totaled 4/14/2010
07 Bentley Continental GT Mulliner Package
87 Porsche 944 NA 5speed black OEM Boxster Wheels - Totaled due to a rock
E92 M3 Stage II+ Dinan 4.10s.....
2011 Mustang GT Procharged... fooking fast
2013 Mini Cooper
13 F10 535 Msport Xdrive some mods Sold
15 F80 YMB M3 DCT DD
Jump to top hyperboost is offline   Reply With Quote
Old Sat, Jun-01-2019, 04:29:38 PM   #6
BADCLOWN
Reputation: 0 BADCLOWN is on a distinguished road
More pictures of the vehicle condition, worked performed, etc? Should probably upload more to this ad
2005 BMW 330i ZHP - BMWP brakes/intake/strut bar/shifter, Coby wraps interior, BBS CHs, Eagle Eye LED tails, GC coilovers, 2x2 CF MTECH2 diffuser, Sprint Booster/sport button mod, 4.5 LCM, Xtrons 9inch HU, BSW stg1, dynamat, M3 sedan dead pedal
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, Phillips LED fogs, CanvasBack full rear coverings
Jump to top BADCLOWN is offline   Reply With Quote
Old Sun, Jun-02-2019, 02:18:18 AM   #7
E.Hands
Here ya go: https://www.mcoupebuyersguide.com/li...istingID=19320
Any questions, comments, requests for particular pictures, opinions, thoughts or history just ask. Come at me Bro!
Old Sun, Jun-02-2019, 02:20:30 AM   #8
E.Hands
Originally Posted by wichonewichone View Post
Beautiful car, glws
Thank You
Old Sun, Jun-02-2019, 02:42:54 AM   #9
E.Hands
Uh no but...
$38,000 and you get a 2001 BMW M Coupe w/ all the extras: In addition, the turbo was upgraded to the Precision Turbo, Gen2 PT6266 CEA DBB CHRA (Competition Engineered Aerodynamics with a Dual Ball Bearing, Center Hung Rotating Assembly). A full custom built, TIG welded, 304 Stainless Steel, Vibrant Muffler exhaust from turbo to tail pipes. New motor mounts. And a RaceLogic Traction Control system in addition to the original DSC. All the paperwork, manuals, receipts, literature, photos, before & after dyno plots, spare parts, a Windows 7 laptop w/ INPA software & hardware for BMW diagnostics, replacement spark plugs, air filter, engine, trans & diff oil, window sticker, owners manual, sales manuals, oil analysis reports, etc…
Old Sun, Jun-02-2019, 03:08:33 AM   #10
bmwahba39
bmwahba39's Avatar
Reputation: 0 bmwahba39 is on a distinguished road
Originally Posted by E.Hands View Post
Uh no but...
$38,000 and you get a 2001 BMW M Coupe w/ all the extras: In addition, the turbo was upgraded to the Precision Turbo, Gen2 PT6266 CEA DBB CHRA (Competition Engineered Aerodynamics with a Dual Ball Bearing, Center Hung Rotating Assembly). A Full custom built, TIG welded, 304 Stainless Steel, Vibrant Muffler exhaust from turbo to tail pipes. New motor mounts. And a RaceLogic Traction Control system in addition to the original DSC. All the paperwork, manuals, receipts, literature, photos, before & after dyno plots, spare parts, a Windows 7 laptop w/ INPA software & hardware for BMW diagnostics, replacement spark plugs, air filter, engine, trans & diff oil, widow sticker, owners manual, sales manuals, oil analysis reports, ect...
if I buy this....I will indeed have a widow sticker from the wife......
GLWS man, beautiful car.
Jump to top bmwahba39 is offline   Reply With Quote
Discussing S-54 Turbo M Coupe in the Cars for Sale/Wanted Forum - Place to list your private cars for sale. ONLY BMW's. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
