Old Tue, Apr-02-2019, 10:40:31 PM   #31
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
Default Re: Avin Avant 4 Thread
Originally Posted by randman View Post
When I first connected it (before I ran the cable through the trunk along the passenger side floor) it seemed fine. After I ran the cable and buttoned everything up, it's awful.
Making me rethink getting this...
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is offline   Reply With Quote
Old Tue, Apr-02-2019, 10:50:43 PM   #32
Radio reception on my Avant 3 seems fine. But I listen to radio like twice a year at most.
Old Tue, Apr-02-2019, 11:03:07 PM   #33
///M Dream
Real Madrid C.F.
///M Dream's Avatar
I use mine about half the time to be honest. If its not going to work for shit would rather not even get the unit. Seems impossible to find something to replace my oem headnav unit (OEM looking, CarPlay, decent radio reception, bluetooth).
Old Tue, Apr-02-2019, 11:18:23 PM   #34
randman
Reputation: 0 randman is on a distinguished road
I ran the cable on the passenger side which means it runs with the battery cable, so this may not have been the best choice. I'm curious if anyone who has run the cable on the driver's side could comment. I'm actually pretty pleased so far. It sleeps, therefore opens right away and doesn't require a two minute boot, all the apps are working and not crashing in the background. To be honest, I don't use the radio anymore anyway, so the reception isn't an issue.
Jump to top randman is offline   Reply With Quote
Old Wed, Apr-03-2019, 06:49:29 PM   #35
xF4m3
Reputation: 0 xF4m3 is on a distinguished road
Germany
Okay so i have routet it along the driver side because i had the fear that i would get alot of noise and stuff because of the battery cable, my radio reception is totally fine. just like it was with the oem nav. I do have the oem antenna though so keep that in mind.
As for dab+...thats another story my dab+ is awful to none existent. Was fine when i installe dit and test it at my parents house, but only while standing there.... but at my place i have 0 rezeption at all but i think my ground for the antenna is bad since i did not remove the paint from the passenger airbad in the A pillar where i hid it. probably will try to fix that or get another antenna.
Jump to top xF4m3 is offline   Reply With Quote
Old Wed, Apr-03-2019, 06:53:14 PM   #36
You can order the actual OEM non-nav antenna cable if you want. Part number 61126912488
Not too expensive, and is the proper length to reach the radio area from the diversity antenna module thing. And it should be properly shielded.
Probably would be cheaper to get your own cable made with the proper ends.
Old Thu, Apr-04-2019, 11:51:17 PM   #37
lippstuh
lippstuh's Avatar
Reputation: 0 lippstuh is on a distinguished road
If you're like me and really want wireless carplay, an adapter is in the works and is set to be in stock by May 25.
https://www.aliexpress.com/item/Carl...983926178.html
/// 2002 Jet Black 6MT Cinnamon
Mods
Karbonius CSL Airbox (1x1) w/ Snorkle CSL-spec DME Kassel MAP sensor Kassel Tuned
JIC Cross/ZMS RS coilovers 996 Brembo BBK w/ CSL/ZCP Rotors F+R Volk OG TE37 Bronze Michelin Pilot Sport 4S 265/35/18
OE CSL trunk OE LED taillights Llumar Air 80 Tint
Next
OZ Hamann PG1 18" custom build VCSL bumper JCSL Diffuser
Jump to top lippstuh is online now   Reply With Quote
Old Sat, Apr-06-2019, 03:40:02 PM   #38
xF4m3
Germany
Originally Posted by ATB88 View Post
I can't help with this but this would be really cool if you end up figuring it out, so I hope that you do!
What are the custom PX5 roms like, what kind of features do they give us?
Okay so i am running the Hal9k Rom now on the avant 4.
Installed flawlessly, no hicups sofar, i can specify apps that wont get killed during sleep or that should restart after sleep etc, the whole unit feels more fluid and resposnive aswell.
And you can customize so much more which i really appreciate.
Old Sat, Apr-06-2019, 05:29:39 PM   #39
Ugh, I might just have to buy a 4.
Old Mon, Apr-08-2019, 11:07:37 PM   #40
1/2past3ci
Reputation: 0 1/2past3ci is on a distinguished road
Please excuse my novice question. I have an avant 2 installed in my M3 that I installed myself in 2014. It has functioned perfectly until I got my car out of storage this year. It is now inoperable. If I buy the avant 4 do I need to run all new wiring or will the wires in place work for a plug and play install? Thanks!
Wes
Jump to top 1/2past3ci is offline   Reply With Quote
Discussing Avin Avant 4 Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
