Old Sat, Dec-01-2018, 01:52:13 AM   #31
frbz
Reputation: 0 frbz is on a distinguished road
Default Re: Squeaky belt/pulley/tensioner - help diagnose
The S54 and S50b3x water pumps are supposed to be far more robust than the US spec parts. Is this true?
Jump to top frbz is offline   Reply With Quote
Old Sun, Dec-02-2018, 08:39:06 PM   #32
M3Stang
Reputation: 0 M3Stang is on a distinguished road
Originally Posted by NolliM3 View Post
I would place my money on the idler pulley...encircled in green. A better-diagnosis would be to use a mechanic stethoscope.
+1 on the stethoscope. Used one to diagnose this noise in the below video. Turned out to be the alternator. Who would have thought.
Jump to top M3Stang is offline   Reply With Quote
Old Mon, Dec-03-2018, 01:20:44 AM   #33
bluptgm3
Default Squeaky belt/pulley/tensioner - help diagnose
The tensioner itself has no replaceable parts. The available needle bearings for the pitman arm are almost unreasonably expensive, even with wholesale discounts. You might as well buy the complete INA assemblies when you factor in the pain of dealing with bearing swapping, and your old cruddy aluminum parts.
Plus the likelihood that the pivot shaft is bad is likely as the bearings/mechanism is not sealed.
All of the assembled parts are available individually, see www.realoem.com. As stated, it is far less expensive to purchase the INA packaged items as the BMW packaged INA part are very expensive.
Old Mon, Dec-03-2018, 01:28:51 AM   #34
bluptgm3
Originally Posted by propchef View Post
This was very helpful, thanks. I removed the fan and loosened the shroud. I had enough room to get everything done and lost less than a cup of coolant.
No need to displace the shroud to tackle this replacement.
Old Mon, Dec-03-2018, 02:38:23 PM   #35
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
^^^it would have been far more difficult if I hadn't. Took me 2 minutes to loosen the shroud.
I didn't go from underneath because I have the MM underpanel and didn't want to remove that.
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Originally Posted by EKaru View Post
STFU Klong!!!!! Go Fuk Yourself!
Jump to top propchef is offline   Reply With Quote
Discussing Squeaky belt/pulley/tensioner - help diagnose in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
